Results 1 to 10 of 15
Thread: How do you lock vectra without setting alarm?
    Regular Member rjw's Avatar
    Oct 2010
    cornwall
    Default How do you lock vectra without setting alarm?
    As per title, how do i lock the vectra without setting the alarm. Got a cross channel ferry trip coming up, and you have to disable the alarm on the ferry, and i dont know how to lock and not enable the alarm.
    Either reach in through the front passenger door and press the lock button on the drivers door panel, or reach in from the rear door and do the same. Then exit out the door you reached across from.
    or
    open drivers window, reach in and press the lock button on the drivers door panel and then close the window on the same panel and getting your arm out the way before it closes.
    - MAKING SURE YOU HAVEN'T LEFT YOUR KEYS IN THE CAR using either method.
    VIP-Member Das's Avatar
    Turdsville
    37 Post(s)
    Vehicle : Lada
    Trim : Riva
    Engine : 6.0 V12
    Year : 1954
    Mileage : 567890987
    Does the alarm set if you just press the button on the fob once? You could try disabling the ultrasonics via the dashboard switch, see if that helps too.
    Regular Member tazdog03's Avatar
    May 2011
    barnoldswick
    hi we just returned from france this week and we never disabled the alarm on the ferry. wasnt aware you had to. all ok tho.
    Quote Originally Posted by rjw View Post
    Where did you read that?
    Ferry operators know some are integrated central locking and alarms, and that doesn't apply
    What they are referring to is vehicles which are locked and have a separate alarm
    Oct 2010
    cornwall
    Brittany ferries clearly state in their conditions of travel that you must ensure your alarm is disabled. as the motion of the ferry crossing can set of the motion sensor alarms
    Regular Member Grahamy's Avatar
    Ryton
    Just press the alarm button on the dashboard before leaving the car , then lock as normal
    Regular Member Ziggy's Avatar
    Leeds
    Vehicle : Saab
    Trim : 9-3 Vert
    Engine : 2.0
    Year : 2000
    P and o north sea are the same. I for one complain if a car alarm goes off. As said I lock mine from inside then close window
    Leeds
    Vehicle : Saab
    Trim : 9-3 Vert
    Engine : 2.0
    Year : 2000
    The internal button just turns off the internal alarm
    Nottinghamshire
    Quote Originally Posted by Grahamy View Post
    This is what I have done for the past 10 years or so and haven't had a problem. Well, I've never been called to return to my car to shut the alarm up anyway. Mind you it's so quiet it wouldn't disturb anyone .
  1. Boot Lock no whirring noise and wont lock or open
    By meridianghost in forum Vectra C / Signum Troubleshooting
    Last Post: 17th December 2012, 14:16
  2. Never mind lock up ya daughters, lock up ya vectras!
    By Jow20 in forum Vectra C / Signum Car Chat
    Last Post: 13th May 2012, 21:45
  3. 2002 Vectra lOCK SET AND ECU
    By dragonuk2000 in forum Electrical & ICE (including SatNav)
    Last Post: 7th February 2010, 12:38
  4. Vectra tailgate won't lock
    By CNC in forum Vectra C / Signum Troubleshooting
    Last Post: 5th January 2010, 00:49
  5. Vec SRI, Keythob Not working: Setting Alarm Off
    By barkzz in forum Vectra C / Signum Car Chat
    Last Post: 12th July 2009, 14:15
vauxhall insignia lock without alarm
lock 2010 astra without setting alarm
vauxhall vectra estate alarm lock set dog
LEAVE DOG IN VAUXHALL INSIGNIA WITHOUT SETTING OFF ALARM
How to lock a vauxhall vectra without turning on the alarm
where is censor for locking on vectra
vauxhall insignia locking car without alarm
how to lock vectra 2008 without alarm
how to lock Vauxhall Vectra 2008 without alarm setting
https:www.vectra-c.comforumshowthread.php165827-How-do-you-lock-vectra-without-setting-alarmpage2
how do you lock an Insignia without putting the alarm on
how to lock vauxhall zafira 2011 elite without activating alarm
lock Vauxhall vectra without setting alarm
can I manually lock vectra without setting alarm off
how do i turn the alarm off on my vauxhall vectra when going on a ferry
how to lock vectra without setting alarm
lock my vectra without setting the alarm
