Results 1 to 10 of 11
Thread: Hazy Headlamp Restoration
    May 2012
    Devon
    Default Hazy Headlamp Restoration
    Hi Guys & Gals,
    seen a few posts on other forums about restoring hazed and yellow plastic headlamps so I thought I would share my experiences.
    When I bought my Vectra I could see that the headlamps were hazed, a usual problem with plastic headlamps I thought, won't be to much to just replace them.
    Then I found that they were £70 a piece, so I did alittle more research and found that a lot of people were swearing by a 3M product called 'Headlight Lens Restoration System #39008'. I found that the kit only cost £20 so I went for it.
    Today I had a go at doing one of my headlamps, the worst one of the two. I was as nervous as hell because there was no going back once I started but I am over the moon with the result.
    BEFORE
    I did use just over half the kit for this one headlamp, so didn't want to risk starting the other one. I have ordered another kit, so £40 for two kits is still a saving of £100 over two new lamps.
    Regards..,
    MT
    Regular Member wardy23's Avatar
    Nov 2011
    North Yorkshire
    Vehicle : vectra
    Trim : sri
    Engine : 2.2
    Mileage : 64000
    i need to do mine but that looks 10x better mate
    Regular Member pompey-pimp's Avatar
    Nov 2009
    Fareham Hampshire
    Vehicle : BMW 520D Touring
    Trim : M Sport Business
    Engine : 2.0 d
    Year : 2010
    A selection of wet and dry 800-2000, 3M fast cut and plastic polish did mine. All for approx £10. Piece of cake to do and well worth it
    Hanging Heaton / Batley
    19 Post(s)
    Trim : SRi (VXR Styling)
    Engine : Z19DTH (Re-mapped)
    Mileage : 110k
    Brasso works same...
    Regular Member MURDO's Avatar
    Co.Clare, Ireland
    Vehicle : Opel Vectra GTS Sport Z18XE
    Trim : Matt Sivler
    Engine : Z18XE
    Mileage : 170,000
    Great work fella. Gives a good sense of self satisfaction knowing you did it on your tod. Makes a big difference...
    Vehicle : .
    Trim : .
    Engine : .
    Year : .
    Had to do mine when I had the GSI, it's well worth the effort. Makes them look brand new again.
    Good work there fella, look a hell of a lot better
    Sent from my iPhone 4 using Forum Runner
    Regular Member renodci's Avatar
    Kent
    Stumbled across this post as I'm keen to restore my headlights - just one question though please - is it ok to use this technique on the SRI dark tinted headlights (not sure how the dark tint is achieved)?
    Sep 2012
    gloucester
    this will obviously restore your lens but does it also make your standard lights any brighter ,i am fitting hids later but would this help for now ?
    Regular Member keith1983's Avatar
    Sheffield / Spalding
    Vehicle : Vectra 1.8 SRi
    Engine : Z18XE
    19 Post(s)
    Mileage : 110k
    Quote Originally Posted by renodci View Post
    Quote Originally Posted by daz263 View Post
    It only cleans the outer lens, look up Perspex polishing on you tube, its the same principle as de-swirling paint work... It's only a protective casing regardless of standard or tinted...
  1. headlight restoration
    By Swedge in forum Detailing and Car Care Discussion
    Last Post: 16th December 2012, 22:42
  2. Volvo restoration (pic heavy)
    By marc vectra sri in forum Detailing and Car Care Discussion
    Last Post: 23rd July 2012, 20:51
  3. Headlight Restoration ?
    By Led in forum Detailing and Car Care Discussion
    Last Post: 18th April 2012, 12:09
  4. MK 2 Cav Restoration
    By Vaux-Man-G in forum The 'Off Topic' room
    Last Post: 24th March 2009, 10:18
