Results 1 to 10 of 11
Thread: 3.0 cdti map sensor
    crook
    Default 3.0 cdti map sensor
    Hi
    i have just got a 2003 signum which when under load,ie going up hills.
    It goes flat and sometimes engine light comes on
    When I checked with code reader... Manifold absolute pressure/barometric circuit shows
    has anyone one had the same pproblem
    Any pics of where the map sensor is and is there any way of checking this
    This is where you want to be :
    http://www.vectra-c.com/forum/forumd...Z30DT-Specific
    It's on the neaside of the engine bay, under the inlet manifold
    Disconnect it, the engine will go straight into Safe Mode, and with a code reader will confirm it is this part
    Full Member Big Sig's Avatar
    Mine did this until I cleaned the boost sensor. Remove the plastic engine cover and it's the top right hand corner (passenger side) it is a small sensor under the "cable tray" with "boost sensor" written on it. It's location is on here somewhere in a pic. Have a poke about though, it's easy to find but a little awkward to get too.
    crook
    Thanks for reply
    i can see boost sensor looks a right sod to get to
    i will try tomorrow
    still don't know where map sensor is?
    Is it near boost sensor
    crook
    Soz for being thick but I couldn't find any pics on your link for map sensor
    Quote Originally Posted by jodiexii View Post
    It sits just behind it, mirror image of where the EGR valve sits
    crook
    Can it be seen from the top, is it easy to remove and can it be checked
    Not directly, you need to remove the engine cover and inlet manifold
    crook
    thanks alot m8internet
    i have engine cover off,i will take inlet manifold off tomorrow
    hope its not a t**t of a job
    do you think if i clean map and boost sensor that will stop the fault
    wirral
    33 Post(s)
    Vehicle : Mk1 renault scenic... I know I know but it drives
    Trim : Basic
    Engine : 1.6 16v
    Theirs a sticky created by me with pics in
  1. 3.0 cdti map sensor
    By jodiexii in forum Y & Z30DT Specific
    Last Post: 9th June 2012, 23:26
  2. For Sale: map sensor for 1.9 cdti 150
    By dbgb25 in forum Parts for sale
    Last Post: 12th March 2012, 18:26
  3. boost sensor 1.9 cdti
    By andy_hare in forum Vectra C / Signum Car Chat
    Last Post: 31st January 2010, 16:21
  4. MAF Sensor CDTi 150
    By Imi in forum Engine & Drivetrain
    Last Post: 10th December 2008, 18:53
