Thread: Warning Signs n Symbols
    Regular Member nikroc's Avatar
    Nov 2007
    DERBY
    17 Post(s)
    Vehicle : 2t
    Trim : standard
    Engine : z20net
    Year : 08
    Mileage : 32000
    Default Warning Signs n Symbols
    Out of the blue my car has thrown an electrical wobbly. I get an array of symbols appear on/in my dash including a warning sign through a sterring wheel,skid/abs light and all the dials stop woking and the trip display shows a letter 'f'..also showed that both headlights were out today..
    car still drives when this is happening. turn off and restart and it returns to normal. No obvious similarities in when it happens.
    Regular Member wildchild's Avatar
    Sep 2011
    west-mids
    Vehicle : vectra c
    Trim : elite
    Engine : 1.9 cdti 16v 150
    Year : 06
    Mileage : 111250
    hi buddy does your battery light come on, can you scroll thru the hidden menu and see what the battery charge rate is on a diesel its approx 14.3-4 v when running anything lower than that could point to the alternator may be wrong thou hth
    gaz
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    As above. Could be the CIM starting to fail too?
    I'll put £1 on the CIM failure
    Next time this happens, put an indicator on (full application) and then cancel it
    If the indicator light remains on, then it is CIM failure
    Nov 2007
    DERBY
    17 Post(s)
    Vehicle : 2t
    Trim : standard
    Engine : z20net
    Year : 08
    Mileage : 32000
    CIM failure?..is this an easy fix?
    Quote Originally Posted by nikroc View Post
    Easy to fix, yes
    Can you do it yourself, not likely
    The CIM module sits in the steering wheel cowling
    Once replaced both keys need to be reprogrammed
    Wait until it occurs more often
    Mine did it once in six months, then it started doing it two or three times a week, and took a photo for the dealership to see
  1. Regen Signs
    By DeeBe in forum Vectra C / Signum Car Chat
    Last Post: 14th August 2011, 03:33
  2. Warning signs?
    By lencuff in forum Electrical & ICE (including SatNav)
    Last Post: 2nd January 2011, 19:03
  3. Hint to what these symbols mean
    By lee866 in forum Vectra C / Signum Car Chat
    Last Post: 28th September 2009, 16:50
  4. Tell Tale Signs
    By B00mer in forum Vectra C / Signum Car Chat
    Last Post: 28th January 2009, 20:29
  5. What are the first signs of a DMF going?
    By Craig1985 in forum Vectra C / Signum Car Chat
    Last Post: 13th August 2008, 09:35
