Thanks Thanks:  1
Thread: Vectra C facelift front fog lamp replacing
    Regular Member L666EAM's Avatar
    Jun 2012
    Scotland
    Default Vectra C facelift front fog lamp replacing
    After looking for help on this matter I found a lot of people suggesting to take off the bumper to replace the fog lamps on the this model, this is simply not the case.
    firstly you need the relevant bulb, I bought mine from Halfords for £5.49, standard fit bulb is an H3 55w 12v
    I replaced the passenger side lamp as this is a know cause for condensation cause by the washer bottle directly above.
    Firstly turn your wheel to the right full lock to allow you access under the wheel arch of the passenger side.
    when you look under and up you'll see a plastic housing with a turnable mount on the bottom of it.
    Turn this and it comes off to reveal the lamp housing. You'll see a wire clip holding the lamp in place. Unclip this and the lamp will come out.
    Simply detach the lamp wire at the end attached to the white connector and reattach the new lamp into the connector. Put the lamp back in place and secure again with the wire clip then put the plastic housing back on by turning it secure.
    10 minute job and no bumper removal required.
    I've attached two photos, one of the housing itself and one of the housing with the bottom mount taken off revealing the lamp housing.
    Hope this helps anyone who needs it.
  2. Thanks big jon thanked for this post
  3. #2
    Jun 2011
    Buckley Flintshire N.Wales
    Vehicle : vectra
    Trim : .....................
    Engine : ....................
    Year : .....
    Your replacing the bulb not the spot lamp
  4. #3
    Jun 2012
    Scotland
    didn't find anything else to replace the bulb other than removing the bumper so I thought I'd post this
  5. #4
    Jun 2009
    South Coast
    8 Post(s)
    Vehicle : Signum & Insignia
    Engine : POS derv
    replacing a bulb is easy though.. replacing the foglight itself can be just as easy.. not sure who told you to take the bumper off though because i wouldn't have...
  6. #5
    Jun 2011
    Vehicle : vectra
    Year : .....
    Quote Originally Posted by L666EAM View Post
    No need to remove the bumper when changing the fog lamp bulb, bumper comes off if you want to change the fog lamp assembly some people manage to do it with the bumper in place but it's far easier to take it off, only takes 10 mins
  7. #6
    Jun 2012
    Scotland
    yeah I agree, it's a doddle replacing when you know how, but trying to find help on how to do it on the net when you don't know how is somewhat different my friend
  1. For Sale: Facelift SRI o/s fog lamp £30!
    By disco dan in forum Parts for sale
    Last Post: 12th September 2011, 18:41
  2. Front Fog Lamp VAUXHALL VECTRA 2006
    By spennny in forum Bodywork & Interior
    Last Post: 3rd November 2008, 13:59
vectra c fog light replacement
vectra c fog light removal
how to change a fog light bulb on a vauxhall vectra 07
vectra c facelift fog light bulb changevectra c fog lamp replacementhow can i tell the difference from a vectra c face lift fog light how to remove fog light vectra c vectra c front fog lamp replacement how to fit vauxhall vectra fog lighthow do i change a foglight bulb on a 2007 vectra cVECTRA C 07 LOWER FRONT FOG LAMPvectra c how to change a fog light vectra c facelift turn signal bulbhow to change front fog light bulb vectra chow to remove front fog lights to vectra cvectra c facelift foglight removalchanging front fog lamps on vectrahow do i replace a front fog light on 2007 vectravectra c facelift fog light removalvectra c facelift fog light bulbvectra c fog light bulb replacementvectra c front fog light removalchange vectra c fog lightvectra c fog lightshow to remove vectra 07 fog light
