Page 1 of 4 123 ... LastLast
Results 1 to 10 of 39
Thread: CD70 into prefacelift Halfcan
    Dec 2005
    Stone, Staffs
    Trim : Edition 100
    Engine : 2.0T
    Default CD70 into prefacelift Halfcan
    Hi guys,
    I have a prefacelift halfcan and Im looking at buying a CD70 kit (headunit and cid) off the bay of e and they are from 2005+ all incl. relevent wires for plug and play (for facelift fullcan obv.)
    Is there any wiring diagrams/pictures I can follow?
    Can the facelift vent be modded to fit the pre/fl? If not what other options is there?
    Im not bothered about steering wheel controls but might add this later if not too much hassle/wiring etc.
    Thanks For any help
    Jim
    P.s I have read the how 2 and done lots of searching but not found anything definitive as to just a straigh forward conversion, most threads want to interchange headunits and screens.
    milton keynes
    Check out one of my old threads , I put a full canbus stereo into a half canbus car.
    Dec 2005
    Stone, Staffs
    Trim : Edition 100
    Engine : 2.0T
    Right from what ive read:
    The vent just needs the top trimming down by 3mm to fit.
    The wiring for the quadlaock is the same but the screen plug needs 2 wires adding (taken from the how 2):
    Pins 1 and 2 need to have brown - earth wires present
    Pins 3 and 5 need to have red +ve 12 Volt wires present
    Some display plugs may have only 1 brown and 1 red.
    If you only have one brown then link pin 1 to 2..
    also if you have just one red then link pin 3 to 5.
    Have I missed anything?
    thanks
    Jim
    Full Member Robsey's Avatar
    North East Cheshire
    10 Post(s)
    Trim : Energy
    Mileage : 131,000
    If you half Half-CAN, then you will currently half an ISO socket on the rear of the head-unit.
    You will need to use an ISO2CAR or SOT122S conversion lead to convert from ISO to Quadlock.
    You only need to modify the vent surround, if you are fitting a wide screen colour display.
    Standard width displays will fit the pre-facelift surround.
    What else ?
    Do not forget to link your head-unit to the display (mid speed CAN wires).
    EHU pin 9 to CID pin 20 (MS CAN High - Green)
    EHU pin 10 to CID pin 19 (MS CAN Low - White)
    If you have climate control, then these wires need moving
    Display pin 20 move to display pin 17 - green
    Display pin 19 move to display pin 18 - white
    You will need an aerial adapter for the radio. (ISO / Din to Fakra) - white socket on the back
    Satnav aerial goes to the blue socket in the corner.
    North East Cheshire
    10 Post(s)
    Trim : Energy
    Mileage : 131,000
    If you need more detailed information, then PM me with a suitable e-mail address, then I can send you some pdf's
    Dec 2005
    Stone, Staffs
    Trim : Edition 100
    Engine : 2.0T
    Thanks for the reply robsey.
    Is this the SOT122S: http://www.ebay.co.uk/itm/SOT-122S-V...item518fd62b09
    Is this the areial adaptor?: http://www.ebay.co.uk/itm/Audi-BMW-F...item3a758eab0f
    PM sent with address
    Thanks for your help
    Jim
    North East Cheshire
    10 Post(s)
    Trim : Energy
    Mileage : 131,000
    Yes - both will fit.
    The bonus of the SOT lead, is that it is fully populated, so you are able to modify the adapter loom wires so that you can add telemute or telephone wires for a bluetooth kit etc.
    Full set of pictures and pdf's sent via e-mail for retro fitting a CD70 and Display.
    Dec 2005
    Stone, Staffs
    Trim : Edition 100
    Engine : 2.0T
    Thanks rob for the email. Plenty of reading there.
    VIP-Member superstuper's Avatar
    Trieste, Italy
    Vehicle : Opel Vectra C
    Trim : Estate F35, Elegance
    Engine : Y22DTR
    Quote Originally Posted by Robsey View Post
    May I also have the files?
    Dec 2005
    Stone, Staffs
    Trim : Edition 100
    Engine : 2.0T
    PM your email and ill send them.
  1. Halfcan & fullcan Steering Wheels & Audio control wiring
    By Woody in forum Electrical & ICE (including SatNav)
    Last Post: 21st January 2013, 11:54
  2. CD70 NAV and Facelift controls in a prefacelift... looks like it?
    By MCD in forum Electrical & ICE (including SatNav)
    Last Post: 5th July 2010, 00:40
  3. Prefacelift Sri Wheels
    By Danwells72 in forum How much is it worth? (THIS SECTION IS NOW CLOSED)
    Last Post: 3rd November 2008, 21:20
  4. Prefacelift Sri Headlights
    By Danwells72 in forum Parts for sale
    Last Post: 30th October 2008, 17:39
vectra cdc 40 into.pre face lift
