Thread: Emissions dash light still on
    Feb 2012
    Uxbridge
    Default Emissions dash light still on
    Hi gents, I've just cleaned and replaced the EGR valve and the light i had on the dash is still on.
    Is there a manual reset for it or do i have to take it back to the stealers?
    Cheers,
    Ed
    Regular Member Das's Avatar
    Yer Maws Bedroom
    40 Post(s)
    Vehicle : Honda Civic
    Engine : 1.8 iVtec
    Mileage : 65500
    Disconnecting the battery for 30 minutes should clear it, if not it will go off of its own accord sure it can take up to ten days though. Or you can also buy a cheap code reader off ebay and reset it via the OBD socket under the ashtray.
    Regular Member CH-VECTRA-ELITE's Avatar
    Frimley
    Engine : CDTI 150 (Z19 DTH)
    Mileage : 140000
    Give it a day or so it will clear. If it doesn't, check the connections again. When i've unplugged mine and plugged it back in it's taken a couple of days driving to work for it to go out.
    Feb 2011
    Selby
    I'd read the codes and find out why it's on - it could be nothing to do with the EGR valve. If you've got a laptop, you can pick up a cheap USB reader for around £10.
    Mar 2012
    Dundee
    Vehicle : GSI
    Trim : (vxr/irmy)
    Engine : 3.2 v6
    Mine went off after a few starts.
    Mar 2011
    Cumbria
    My emission light is like that at minute! Stays on for few days then sometimes clears itself! According to code being thrown up i need new MAF sensor!
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800 non vvt
    Mileage : 142000
    if it is the egr the light it will go away after a few starts if not you may have another code for something else
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Mileage : 142000
    make sure you have cleaned it out properly if the light still stays on
    EGR valve on the Solenoid side got stuck and needed cleaning out once cleaned and put back togeather running like a dream. save yourself some money and give the How 2 a try. The way I look at it if it's broken anyway and needs changing you might as well try and fix it and save yourself some money...
    have a look at this
    http://www.vectra-c.com/forum/showth...eplacing/page3
    how 2 in a video
    http://www.youtube.com/user/Absolute...?feature=watch
  1. Emissions Light Help Please
    By veccydave in forum Engine & Drivetrain
    Last Post: 4th January 2012, 14:17
  2. emissions light
    By rick1965 in forum Vectra C / Signum Car Chat
    Last Post: 30th December 2010, 23:34
  3. Emissions Light
    By Frp01 in forum Engine & Drivetrain
    Last Post: 23rd March 2010, 09:31
  4. Emissions light on!
    By JohnThePom in forum Engine & Drivetrain
    Last Post: 10th December 2007, 13:35
  5. Replies: 1
    Last Post: 1st September 2007, 12:17
vectra emissions dash light
