Thread: Tools for rear light cluster change?
    Jun 2012
    Surrey, UK
    Default Tools for rear light cluster change?
    Have bought a new rear light unit on my 2008 Vectra hatchback after some kind soul bashed the current one in. Looks dead simple to change it over so not worried about that but I've never attempted anything like this before and I'm not sure what I need to undo the nuts holding it in place. I have no tools whatsoever so am starting from scratch.
    Any help would be great thanks.
    Regular Member boodoo warrior's Avatar
    May 2011
    derby
    i did mine when i bought it as i have an sri but it had a combi on drivers side that wasnt smoked, just a couple of nuts (10mm) i think on the inside and it just pulls out, disconnect it, change the light fitting over to the new and just pop it back in and put nuts back on, its dead easy m8
    lanark
    Vehicle : Insignia Elite Nav
    Year : 2012
    Mileage : 9k
    there are 3 nuts and one of the nuts on the nearside is a bit of a pig to get out
    Wondering lonely as a cloud
    26 Post(s)
    Vehicle : M5
    Trim : Nothing needs adding
    Engine : 5.0 V10
    Year : 07
    Mileage : 37000
    Since you have no tools go to Halfords and get a cheap socket set you will need a 10mm for this job also if you are planning any other small tasks in the future as you get adventurous get a set of Torx bits as well the car is covered in T20's. If that is too rich for you blood change your location from UK to something more specific and you never know some member local to you will probably give you a hand and is likely to have some tools as well.
    Regular Member coldo's Avatar
    Scotland
    Quote Originally Posted by paulhb View Post
    +1
    Vauxhall do love there T20's dont they
    Jun 2012
    Surrey, UK
    Thanks a lot for that, really helpful. I'll head off to Halfords then. I do like the idea of doing this sort of thing myself so will take the hint about the T20s!
    And if all fails I'll edit my location...
    VIP-Member
    40 Post(s)
    Vehicle : `
    Trim : `
    Engine : `
    Year : `
    Mileage : `
    To change the rear light clusters all you will need is a pair of pliers to undo the nuts.
    Jun 2012
    Surrey, UK
    Thanks everyone, job done. Extremely simple but whoever said the third nut was a ****** to get to wasn't wrong! Anyway, it's a small thing but I'm pretty pleased with myself so thanks for the help
    Regular Member rjw's Avatar
    Oct 2010
    cornwall
    8mm nuts, look at their positions on the new light cluster for where they are. Did mine a couple of days back. 3 nuts is all, easiest to disconnect the wiring for the bulbs, and remove the bulb holder from the cluster first, the top nut on the nearside is a b***h due to the fuse box set up.
  1. Rear light cluster
    By Stevie-B in forum Vectra C / Signum Car Chat
    Last Post: 1st May 2009, 16:38
  2. Rear light cluster
    By KSD in forum Styling
    Last Post: 3rd February 2008, 15:26
  3. Rear Light Cluster
    By Neil in forum Bodywork & Interior
    Last Post: 16th February 2007, 08:15
