Thread: how to disable low washer fluid level
    Regular Member mrk's Avatar
    Vehicle : vectra hatchback
    Trim : improving
    Engine : 1.9cdti mas remap
    Year : 06
    Default how to disable low washer fluid level
    i fitted cd70 a while ago and always have the low level warningis there any easy way round this short of fitting the correct bottle withthe sensor incheers in advance Mrk
    Middlesex
    Trim : SRI
    Engine : CDTI 150 (Z19 DTH)
    Mileage : 100k
    You can do a few things:
    1) Get a sensor and bung and drill your existing bottle and fit the sensor (sealing it in with silicone), as you will 99% have the plug there ready for the sensor anyway. This is what I did and its 100% working as it should.
    2) Bridge the pins in the plug for the sensor on the bottle so it always things its full using either a wire from one side of he plug to the other etc etc...
    3) Disable Check control in the Screen (DIS) using Tech II or Vauxcom.. Problem here will be that you will get no warnings at all - i.e. bulbs / safeguard etc etc
    HTH
    A
    Trim : improving
    Year : 06
    cheers mate very prompt reply. i will probably get a bottle with sensor 2nd hand
    Regular Member coldo's Avatar
    Scotland
    I had the same issue when I upgraded from my TID to GID screen. I bought the sensor and grommet etc plugged it all in and it made no difference. Upon further investigation I discovered the issue was with the plug that connected to the sensor which had rusted / corroded so badly that the pins would not make contact.. even when I bridged it using a paper clip to test the function.
    In the end the only way I could resolve the problem was to cut the plug off and connect the wires together effectively closing the circuit permanently. Hey presto warning sign has gone and I have never had to look back since.
    The wiring loom is taped up under the light connected to the light wiring loom (or it was in my car anyway).
    Regular Member Das's Avatar
    Yer Maws Bedroom
    40 Post(s)
    Vehicle : Honda Civic
    Engine : 1.8 iVtec
    Mileage : 65500
    Quote Originally Posted by AntSSSS View Post
    Yep your existing bottle will take the sensor. Hole required is a 20mm iirc. I have a sensor and grommet for sale in the parts section.
    http://www.vectra-c.com/forum/showth...tic&highlight=
    Scotland
    You dont happen to have the plug also that is at the end of the loom? Would be very interested if you do?
    Mar 2012
    Dundee
    Vehicle : GSI
    Trim : (vxr/irmy)
    Engine : 3.2 v6
    I hate seeing errors mine is the same i am going to sort mine when i do my lights since the bumper will be off anyway i had a look at mine and tried to bridge it the plug was rusty too lol
    Scotland
    I had considered hard wiring mine to the senor (soldering the wires instead with plenty of insulation also).... Idealy I would like to replace the plug instead...
  1. Washer Fluid level sensor???
    By Ian S100 in forum Vectra C / Signum Car Chat
    Last Post: 9th February 2016, 00:15
  2. how to disable washer fluid sensor
    By dcm23251981 in forum Electrical & ICE (including SatNav)
    Last Post: 3rd February 2012, 09:24
  3. clutch fluid level? how do i check it?
    By renton608 in forum Engine & Drivetrain
    Last Post: 8th February 2011, 19:25
  4. PAS Fluid level
    By Rob_the_Scot in forum Suspension, Wheels & Brakes
    Last Post: 8th March 2007, 00:00
vectra c wash fluid sensor location
vectra c how to turn off washer fluid low message
vectra c screen wash level sensor
vectra c washing fluid level notification fuse box
vectra c washing fluid level pins
opel signum windshield liquid notification remove
vectra c screen wash message
