Anyone in the South East had their trip computers activated and who did you use?
Asked a couple dealers and they were like ....
Cheers
Cheers
I can mate - what you got / need?
Yip - so you need the code index programmed in the DIS..
Not a problem I can do that for you... What engine do you have.
Im in Ashford Middlesex BTW - dont know if thats too far for you?
ahhh - you have a cdti dont you, didnt we talk about the cam belt
Well mate - the offer is there - not a problem..
I take it the screen and unit are paired - so all works, i.e. all radio functions.
You can see what the current code index is thats programmed at the moment by doing the following:
Start car
Press the main button
Press and hold the settings button until you get a beep
Press the BC button and that will take you to the normal screen you are presented with when you press BC (so in your case timer)
Press the BC button again and you will go into the 'test' menu - here you can see what the 'code' currently is - will be something like 012 or 013 or 014 etc etc...
Press the BC button again to cycle through the hidden test menu,
Let me know what the current code is and also the software verison date.
