Results 1 to 10 of 13
Thread: How to tell if the Cam Belt and Water Pump has been changed?
    Jan 2012
    Milton keynes
    Trim : M Sport and Design
    Mileage : 38100
    Default How to tell if the Cam Belt and Water Pump has been changed?
    As the title suggests... How do you tell? The garage I bought the car from said they had it done when it came in but havent put the paper work in the pack.
    Its the same with the EGR valve, but I can tell that been changed as it's obviously new.
    So would it be quite obvious if I just popped the cover off and had a look? I've done less than 1k miles in it since I bought it.
    Middlesex
    Trim : SRI
    Engine : CDTI 150 (Z19 DTH)
    Mileage : 100k
    What engine mate?
    Jan 2012
    Milton keynes
    Mileage : 38100
    z19dt? I think its the 120
    Middlesex
    Trim : SRI
    Mileage : 100k
    OK - the z19dt is the 120 , the z19dth is the 150..
    TBH you can have a visual inspection with the belt cover removed - and if its really new you will see the print on the belt still all look fresh and the water pump should look new compaired to the block etc....
    Apart from that not much really you can do.. I would say that if you dont trust its been done - and you are at the age / mileage, change it mate.. Not worth the mess it leaves when it fails!
    Middlesex
    Trim : SRI
    Mileage : 100k
    Also if its a genuine VX belt there will be yellow timing lines printed on the belt - and a GM part number on the back plate of the water pump and tensioner.
    Jan 2012
    Milton keynes
    Mileage : 38100
    Okay, cheers for that, I'll have a look tomorrow. Hopefully wont have a nasty surprise.... lol
    Middlesex
    Trim : SRI
    Mileage : 100k
    Quote Originally Posted by Chunklamb View Post
    Did they say if they did just the belt - or a belt kit, so including the tensioner and roller pulley?
    Take some pics mate and post them here and we can help
    Ive done about 6 belt kits now on the 1.9 CDTI in the space of a month - lol - and I have one in this weekend...
    Jan 2012
    Milton keynes
    Mileage : 38100
    They just said belt and water pump...
    Middlesex
    Trim : SRI
    Mileage : 100k
    Hmm - what mileage do you have.
    I wouldnt change a belt without a new tensioner and roller pulley TBH.. Its not worth it.. Take some pics tomorrow and lets see... But if your only taking the black plastic cover off you wont see the tensioner and roller pulley.. At least it will give you an idea,
    I'd be supprised if a garage would change a belt without the full belt kit TBH - but then again you never know... Was it a VX garage or indie?
    Jan 2012
    Milton keynes
    Mileage : 38100
    It was an independent, but their service has been great with everything to do with the car so far. I'm just embarrassed to go back and see them after the car I traded in lol
  1. Cam belt and water pump
    By tommythomson12 in forum Vectra C / Signum Car Chat
    Last Post: 7th August 2013, 15:06
  2. timing belt and water pump
    By MARTIN FROM LLAN in forum Vectra C / Signum Car Chat
    Last Post: 15th December 2012, 20:33
  3. Cambelt and water pump changed today
    By marky2027 in forum Vectra C / Signum Car Chat
    Last Post: 24th March 2011, 20:02
  4. Cam belt+water pump?
    By Martinlw in forum Engine & Drivetrain
    Last Post: 13th October 2009, 18:55
