Thread: air bag sensor
    Oct 2007
    nottingham
    Default air bag sensor
    Hi
    Can anybody tell me where the n/side airbag sensor is please,have got new airbag module and curtain airbag just need the sensor now for n/side impact.
    Thanks Guys
    tommy
    Admin plasma's Avatar
    On the Forum
    325 Post(s)
    Engine : 150
    Mileage : 74000
    bottom bit of the B pillar, you'll need to remove the entire side sill to see and gain access to it? Is it broken?
    Plasma's Tech2 services are now partially open and able to provide services
    Come Join our new forum Insignia Owners.com for all your Insignia chat and needs
    Oct 2007
    nottingham
    Quote Originally Posted by plasma View Post
    hi Plasma
    No it is not broken but thought it would need replacing after side airbag deployment,does it not need replacing.Thanks
    tommy
    On the Forum
    325 Post(s)
    Engine : 150
    Mileage : 74000
    i dont believe it does unless it broken.
    Oct 2007
    nottingham
    Hi Plasma
    stupid question,but how do you know if it is broken?. Thanks for your help.
    tommy
    On the Forum
    325 Post(s)
    Engine : 150
    Mileage : 74000
    if its in two bits lol. I'm not 100% sure but as its just a sensor and senses 'G Force' I dont believe its a one time use item, but if your not sure then grab yourself another one, seen them on ebay for £10 or so
    Oct 2007
    nottingham
    hi Plasma
    if the sensor is no good,will it damage the module and new airbags,bit weary of them firing.
    thanks tommy
    On the Forum
    325 Post(s)
    Engine : 150
    Mileage : 74000
    send me your old one and i'll plug it into a donor car and test it lol
    Oct 2007
    nottingham
    hi ok thanks will try a bit more research first,but thanks for your kind offer.
    tommy
    wirral
    58 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Test it with multimeter asking as its in correct ohm range it should be fine
  1. Replies: 3
    Last Post: 13th August 2012, 22:25
  2. P0141-04 o2 sensor heater circuit open (bank 1 sensor 2)
    By Mark1892 in forum Engine & Drivetrain
    Last Post: 3rd August 2012, 09:19
  3. Fitting & Installation of ABS Harness & brake Help sensor sensor
    By Elahi_786 in forum Suspension, Wheels & Brakes
    Last Post: 17th April 2012, 20:46
