Thread: Question for the oil experts.
    East Kilbride
    Engine : 3.2 v6
    Mileage : 110,000
    Default Question for the oil experts.
    I ordered Castrol Magnatec to do an oil change on my Signum 3.2.
    Eurocarparts have sent, ahem, Ford spec instead of Vauxhall/ GM spec.The question is do I use it or return it, what are your thoughts?
    3.2 v6 Signum and loving it
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Depends how fussy you are buddy tbh
    IMO 5w-30 fully synth is 5w-30 fully synth no matter what they have written on the bottle. Not sure if there is a genuine difference or if it's just for manufacturers warrenty purposes tbh
    I personally always use the "For Vauxhall" magnatec but I am fussy
    Found this on another website, make up your own mind
    If you took the Ford oil and the Vauxhall oil and looked at them - you wouldn't really see much difference and to many people, as they are both a 5W-30 - they would assume they are the same ( and many people do ! ) - but unfortunately they are not. It's all to do with the specification and HTHS values ( High temperature high shear ) - basically although they are both classed as a 5W-30, at 150ºc if you measured the viscosity of the two oil oils, the Ford one because it is designed to meet the ACEA specification A1/B1 A5/B5 ( and Ford WSS-M2C-913C ) is classed as fuel efficient with a low HTHS value and would be thinner viscosity than that of the same viscosity non fuel efficient specification ACEA A3/B4 with a higher HTHS value. If you consider that the main function of an oil is to keep fast moving metal surfaces apart - if the oil isn't thick enough, then you could get metal to metal contact and wear would quickly take place. By the way ACEA specs - A is petrol, B is diesel.
    So, using a fuel efficient oil in an engine not designed for that type of oil could damage the engine - and that's why if you look in a Vauxhall handbook, it will likely say " Vauxhall does not recommend the use of fuel efficient oils " - because they know that they are thinner, and if used could cause engine damage. Also, Vauxhall run extended drain intervals whereas Ford do not, so the specification of the Vauxhall oils take into account this as well - hence the need for the Vauxhall spec - GM-LL-A/B-025 ( or DEXOS 2 now )
    That's why there are so many different oils on the market - not because the oil companies want it that way, but because of all the different specifications the oils have to meet - and in many instances, by meeting one specification, you aren't able to meet another with the same oil ... so need another oil ...
    East Kilbride
    Engine : 3.2 v6
    Mileage : 110,000
    Cheers John,
    Thanks for quick reply. I will probably use it, unless someone tells me it
    will blow my engine up. LOL. Just wait till we see the replies now.
    Forfar, Scotland
    Trim : LE/VXR
    Year : 13/07
    As per my edited post bud
    Tbh, they sent the wrong stuff. Send it back and tell them you want the stuff you ordered
    Or depending on how much it cost, send it back and get it from halfords, it's 17.50 a bottle
    East Kilbride
    Engine : 3.2 v6
    Mileage : 110,000
    Read edited post, thanks mate it is going back.
    Regular Member Das's Avatar
    Here
    33 Post(s)
    Vehicle : Lada
    Trim : Riva
    Engine : 6.0 V12
    Year : 1954
    IIRC the Ford spec Magntec is designed for better MPG, I doubt it will make much odds to your 3.2 john, lol.
    Jul 2009
    Brighton
    Different oils have different detergent that are designed for your engine, bearings , seals etc. The viscosity of oil is just one part of it's specification. Send it back and get what you originally ordered.
    May 2012
    chelmsford
    used it last 15 years mate. you want a3 b4 magnatec in them. ive had it in my 3.2 for a year now with no probs atall. the one i go for normally has opel cars on the bottle
    East Kilbride
    Engine : 3.2 v6
    Mileage : 110,000
    Thanks for replies guys. It is going back and replaced with correct spec. Well done Eurocarparts for prompt and efficient service.
    Wales
    Right move IMO!
    I remember reading somewhere that the oil is specifically low sulpher for the DPF which is in your signum. If you had a non-DPF vehicle, I would say you should not be so concerned.
  1. Replies: 6
    Last Post: 1st August 2012, 20:42
  2. a bit of help from the experts:)
    By macs_silviu in forum Bodywork & Interior
    Last Post: 9th July 2012, 22:41
  3. MS Excel - Any Experts?
    By Aidi in forum The 'Off Topic' room
    Last Post: 22nd April 2012, 17:24
  4. Looking for experts
    By Rebellion8878 in forum South Central (RO - Harrysdad, ARO - matty2fatty)
    Last Post: 4th March 2011, 12:47
  5. Question for DSLR experts, if we have any.
    By 67688c in forum The 'Off Topic' room
    Last Post: 2nd May 2010, 07:48
