Thread: UHP4 bluetooth loom question
    Forum Moderator John LE's Avatar
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Default UHP4 bluetooth loom question
    I have the wiring in place for the Mic in the headlining. Does that mean I should have all of the other wiring too?
    And does the bluetooth work with the iPhone 4?
    Admin plasma's Avatar
    On the Forum
    184 Post(s)
    Engine : 150
    Mileage : 74000
    No, and possibly
    Just because you have the black plastic 2 pin connector (just to the right if u remove the interior light, you may not have the ribbon cable flylead, and pound to a penny you wont have the bluetooth loom which would be situated at the back of the oddments tray which is the one underneath the heater controls
    Plasma's Tech2 services are now partially open and able to provide services
    Come Join our new forum Insignia Owners.com for all your Insignia chat and needs
    Forfar, Scotland
    Trim : LE/VXR
    Year : 13/07
    Sorry Dean, I should have been clearer. I have the 2 pin plug and the wires run down the a-pillar. I'll check behind the storage tray for the multiplug, it'll save a bit of hassle
    On the Forum
    184 Post(s)
    Engine : 150
    Mileage : 74000
    the above still applies
    you'll find almost all facelift/fullcan cars will have the black 2 pin plug as part of the body loom
    Forfar, Scotland
    Trim : LE/VXR
    Year : 13/07
    Do all of the connections from the UHP 4 go directly into the cd70?
    On the Forum
    184 Post(s)
    Engine : 150
    Mileage : 74000
    No mate, they splice into the loom at various points, ie Postive, Negative supplies, Canbus is linked either to display or ECC depending what you have. Mic is directly out to the roof loom. Speech/Sound is feed into the CD70 though as is mute, there are parrot leads out there with the UHP loom attached to it so you just plug it in to the radio as an extension harness with the microphone on a flying lead.
    Wondering lonely as a cloud
    21 Post(s)
    Vehicle : M5
    Trim : Nothing needs adding
    Engine : 5.0 V10
    Year : 07
    Mileage : 37000
    Mine had the wires in the roof lining John but none of the rest of it, they tended to only put the harness in if the option was selected at the factory as it was a factory fit option only, and then if it had been selected as an option you would have the UHP in behind. Vx never offered this as a retrofit so wiring would have been UHP installed as well especially on the facelift as you well know they cut down on just about everything they could.
    Regular Member 4ndy's Avatar
    Oct 2010
    Glasgow
    There are UHP4 microphones for sale on ebay if you want to start preparing for your next modification! The complete kits pop up from time to time for about the £200 mark.
    On the Forum
    184 Post(s)
    Engine : 150
    Mileage : 74000
    the mic's are only £32 brand new
    Full Member Sebastian's Avatar
    Electric Heated Recaro Leather
    31 Post(s)
    Engine : 1.9 DTH
    It works fine even with iPhone 4s also phone book synching well too...
  1. UHP4 bluetooth loom CD70
    By nipmads in forum Electrical & ICE (including SatNav)
    Last Post: 28th August 2012, 22:59
  2. CD30 MP3 vs. UHP4 bluetooth kit
    By Hummelshøj in forum Vectra C / Signum Car Chat
    Last Post: 11th July 2011, 17:16
  3. Location uhp4 bluetooth original
    By msqualo in forum Vectra C / Signum Car Chat
    Last Post: 10th April 2011, 22:16
vectra c uhp4 bluetooth
UHP4 Vectra location
