Results 1 to 10 of 13
Thread: Internal light loom plug. What are they for??
    Jan 2012
    Houghton Le Spring
    Vehicle : SRI 150
    Trim : Smart and Bad!
    Mileage : 105000
    Default Internal light loom plug. What are they for??
    I was cleaning the plugs as the end one for ultrasonic alarm sensor was playing up. (u can see silicone on the roof that fixed the leak)
    The black plug that connects to the internal light. 4 plugs goes in there, one for ultrasonic sensor which is being used, (far right) and the lights for map reading and internal light connects to the 3rd one from the right
    1- alarm sensor
    2- ??? What connects to that???
    3- light unit
    4- ??? What connects to that?
    Obviously the plugs goes to the black plug but what is used?? Would like to complete the set!
    Full Member coldo's Avatar
    Scotland
    Is it feeds for the map lights ...?
    Ely, Cambridgeshire
    60 Post(s)
    Vehicle : Insignia Tourer
    Engine : 2.0 CDTI (160ps)
    Year : 2010
    I'd have to pull mine out to check as I never bothered tracing where they came from just plugged them in when I fitted mine, but could it be the sunvisor lights for illuminated sunvisors? If it leads to small plug each side above the sunvisors then you've got your suspects
    Jan 2012
    Houghton Le Spring
    Vehicle : SRI 150
    Mileage : 105000
    Quote Originally Posted by Ian-Highlander
    Do u have one? Can you confirm or summat to do with auto dimming rear mirrors? Would make my day if it does both :-))))
    Jan 2012
    Houghton Le Spring
    Vehicle : SRI 150
    Mileage : 105000
    Quote Originally Posted by coldo
    I've mapreading lights and standard, it's 2 more sockets for something else. Maybe sunvisors mirror/lamp and/or auto dimming rear mirror?
    Jan 2012
    Houghton Le Spring
    Vehicle : SRI 150
    Mileage : 105000
    Anyone??
    Scotland
    I thought they were on a different loom?
    Could it to be something to do with a sunroof if you have one fitted...
    Prehaps somethign to do witht he bluetooth moduel if that's fitted.
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    I would think it'll be the feeds for the rear interior light and the illuminated sun visors
    Have you tried tracing the wires from the hole in the headlining to see where they go? You should be able to see the illuminated sun visor ones from there
    Jan 2012
    Houghton Le Spring
    Vehicle : SRI 150
    Mileage : 105000
    The wire goes to the main cuircuit so no cant trace it, do anyone know what 2 sockets are for? Need a confirmation of someone knowing?? An estate don't have rear internal lights, I wonder if it can be done using grab handles with lights if that is one??
    Ely, Cambridgeshire
    60 Post(s)
    Year : 2010
    Quote Originally Posted by Humourbash View Post
    Errm, it's nothing to do with chassis type it's down to the spec. Got rear internal lights in my estate, came like that from the factory...
    Crap pic from a couple of years ago, but it's the only one I could find that showed it.
  1. Internal light bulbs??
    By SlowCoach in forum Electrical & ICE (including SatNav)
    Last Post: 11th October 2012, 07:35
  2. Internal light conversion, help?
    By carperjake in forum Bodywork & Interior
    Last Post: 28th June 2012, 15:27
  3. Rubber plug on roof above internal light leak
    By SlowCoach in forum Bodywork & Interior
    Last Post: 3rd May 2012, 09:24
  4. Roof Loom Plug
    By Das in forum Electrical & ICE (including SatNav)
    Last Post: 9th March 2011, 13:13
  5. Microphone plug on wiring loom
    By LeeU in forum Electrical & ICE (including SatNav)
    Last Post: 8th November 2010, 21:25
