Thread: nut for additional earth lead
    Regular Member J P S's Avatar
    Sep 2011
    Birmingham
    Vehicle : 2007 1.9cdti sri 150 estate
    Trim : sri
    Engine : 1.9cdti 150
    Default nut for additional earth lead
    i have the lead in place but not bolted down on the engine end as i dont seem to have the correct nut.
    does anyone know what i would need from halfords, as going there for oil and sockets anyway.
    thanks
    Regular Member Mads's Avatar
    Ipswich,.UK
    im not sure i found a nut to fit it but when i tightened it it didnt bite, i think it doesn't have a normal tread. i cut it off and drilled a hole through where it was and fitted a normal nut and bolt, much better. HTH
    Sep 2011
    Birmingham
    Trim : sri
    trying to avoid doing that but it is an option, the correct bolt would be a lot easier, i just hoped someone had bought one they found to fit.
    failing that i will just keep looking, one will turn up
    Feb 2011
    Selby
    Instead of Halfords, why not drive to a small, local nuts and bolts company and ask them for help? They'll be able to measure the thread pitch and diameter and sell you a suitable nut for pennies. Look in your Yellow Pages (or yell.com) under 'Fasteners' or 'Nuts and Bolts'
    Sep 2011
    Birmingham
    Trim : sri
    i did think of that, there is one in brum i used years ago but just wondered about halfords as i am going there anyway.
    might see if that place in brum is still there actually.
    Dec 2011
    Seaham
    Places like Wilkinsons and B&Q also do nuts, but you would still only be guessing.
    Regular Member Neve'o's Avatar
    Norfolk
    Vehicle : Vectra SRi 150 Hatch
    Mileage : 69'000
    I drilled a fresh hole and used an normal nut and bolt after not having any in my 'nuts' jar that fitted, its a strange thread, almost like its for plastic nuts.
    Sep 2011
    Birmingham
    Trim : sri
    ok then. yes it does seem to have an odd thread. does the little thing its attached to come off at all?
    if so i may take it into a fasteners place and see what they can find, cheaply of course.
    i am at work and cant recall if it is removable
    Feb 2011
    Selby
    I'd take a guess it's a metric fine rather than metric course thread- though as I've never looked at it, I really am just guessing It would be useful to get a fastener place to find out what it actually is, then you can post on here so that in future people can do a search and find out. And they'll thank you for going to the trouble
    Sep 2011
    Birmingham
    Trim : sri
    when i am next under the bonnet i will see if i can unbolt the bit and then see what i can find.
    if i find out what it is i will try and buy a few bolts, they probably wont be too keen on selling one anyway!
  1. earth lead locations?
    By victorM in forum Electrical & ICE (including SatNav)
    Last Post: 5th February 2012, 18:15
  2. Additional switches
    By chris_20 in forum Vectra C / Signum Car Chat
    Last Post: 25th September 2010, 00:43
  3. Additional gauges
    By greg_t in forum Vectra C / Signum Car Chat
    Last Post: 8th February 2009, 18:51
  4. Additional lights
    By rob mc in forum Electrical & ICE (including SatNav)
    Last Post: 13th September 2008, 20:58
