Thread: Change air con rad any tips
    Feb 2006
    Burton On trent
    Default Change air con rad any tips
    Had the air con re gassed at Kwik Fit for £49, this worked for a day or so and failed so I popped back and they say there is a leak and removed the remainder gas and offered a free re gas when repaired.
    There machine which checks for leaks prior to gassing tests the main pipes but no the rad, I cannot see any oil on any pipes in the engine bay so I believe the rad is to blame so looking at changing this.
    Looking at the rad through the grill it looks like it's been shot at with an MG42.
    Anyone changed their condensing rad and if so are there any issues, also when connecting the pipes to the new rad is there any joining solution etc I should use.
    thanks
    Jul 2009
    Wiltshire
    I did a How2 a while back. I think the pics still work. Not hard at all..
    http://www.vectra-c.com/forum/showth...lace-condensor
    Hope that helps
    Feb 2006
    Burton On trent
    Quote Originally Posted by tonyo View Post
    Hope that helps
    Nice one, how many seals and studs are there to order? also did you use any joining solution on the rubber seals ec
    thanks
    Jul 2009
    Wiltshire
    Quote Originally Posted by masonic View Post
    thanks
    Two Studs, and one of each of the seals. It has been pointed out in discussions that you can get the seals for a lot less than Vaux charged me for them.
    No, there is no need to put any other form of sealant on the seals.
    Steeple Claydon
    Easy job on Vectra C takes around 1 hour remove front bumper and easy access would recomend getting new plastic studs for refitting bumper as the tend to break when taking out
    found a place in Birmingham that will supply original part for Aprox £100-00 delivered to your door but sorry cant find details just search on line for Vectra Aircon condensor
  1. ~~~Top Tips~~~
    By Das in forum Detailing and Car Care Discussion
    Last Post: 27th April 2011, 21:35
  2. Any Useful tips for 2.0 T
    By Stivagorm in forum Tuning
    Last Post: 6th May 2009, 06:26
  3. what sort of price to change my exhaust tips
    By Morephun in forum Styling
    Last Post: 11th April 2009, 02:23
  4. any tips on how to cut the rear valance to show my exhaust tips
    By eaglepva in forum Vectra C / Signum Car Chat
    Last Post: 2nd July 2008, 18:58
  5. top tips
    By mike houston in forum Comedy & Humour
    Last Post: 1st May 2007, 09:31
