Thread: Noise when clutch disengaged
    Regular Member fishphone's Avatar
    May 2007
    Vehicle : Insignia Tourer
    Trim : Elite NAV
    Engine : 2.0 CDTI
    Default Noise when clutch disengaged
    07 plate 1.9 Signum:
    Graunching sound from engine when clutch pedal is fully depressed as far as it will go. If the pressure is released a little bit the noise stops. Car running fine otherwise. Have read a few posts about thrust bearings and DMF, can anyone advise what this might be please? Am really starting to get paranoid about my cdti now. I previously had a 2.2 petrol from almost new, four years and 80k and only serious fault was air con compressor which packed up just before the warranty expired. Got the 1.9cdti 4 years old but with only 15k, has just had egr replaced at 40k.
    East Midlands
    I will say thrust bearing mate,dmf will be constant noise.
    Regular Member Mr Owens's Avatar
    Jun 2012
    Wickford
    Trim : Sri
    Engine : 2.2 direct
    Definitely the thrust bearing, but to change that you will be replacing the whole clutch kit and any mechanic that knows what they are doing will check the dual mass flywheel when they remove the pressure plate
    May 2007
    Trim : Elite NAV
    Engine : 2.0 CDTI
    Thanks for the prompt replies guys. Does this need fixing straight away or can it wait, or will it fail fully at some point? Any rough estimates as to cost of sorting it?
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800 non vvt
    Mileage : 142000
    Quote Originally Posted by fishphone View Post
    here you go mate
    http://www.vectra-c.com/forum/showth...-clutch-fitted
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Mileage : 142000
    also this may help
    http://www.vectra-c.com/forum/showth...is-this-normal
    what mileage has the car done?
  1. Clutch noise
    By benwalters82 in forum Engine & Drivetrain
    Last Post: 1st July 2010, 08:10
  2. noise on clutch
    By gasrac in forum Engine & Drivetrain
    Last Post: 24th May 2009, 18:39
  3. Clutch noise?
    By aerodynamic18 in forum Vectra C / Signum Car Chat
    Last Post: 14th February 2009, 18:20
  4. Noise on clutch
    By PeteRs in forum Vectra C / Signum Car Chat
    Last Post: 29th February 2008, 11:54
  5. Clutch Noise / Kit
    By robzc in forum Engine & Drivetrain
    Last Post: 23rd March 2007, 08:11
vectra c clunks.when release clucth
