Thread: Key Fob programing?
    Regular Member Sierra2's Avatar
    Sep 2010
    London
    Trim : SRI
    Engine : 1.9cdti (120)
    Mileage : 45k
    Default Key Fob programing?
    Just tried my 2nd key fob and it doesn't work. Any idea how hard this is to program, will it need Tech2?.
    Full Member plasma's Avatar
    On the Forum
    346 Post(s)
    Engine : 150
    Mileage : 74000
    Did it work before? If it did then it may need a new battery, does it still start the car?
    Regular Member MrDerv's Avatar
    Nov 2011
    North East (Beamish)
    If it was already prorammed to the car, try a fresh battery in the key.
    To re-learn an existing key, insert into the ignition, turn ignition on, then press the lock and unlock buttons on the fob 3 times each. When you turn the ignition off, your fob should now work perfectly.
    Sep 2010
    London
    Trim : SRI
    Mileage : 45k
    Thanks guy's. I bought it from a VX dealer over a year ago. Diddn't check it (stupidly...) No, once the dash has done its start up the Service/spanner light flashes and it won't turn over (although the key is turning the lock). I'll swap the battery from the one that does work and try that, or is there a risk I might screw the working one up and leave myself stranded?
    Chaz
    On the Forum
    346 Post(s)
    Engine : 150
    Mileage : 74000
    Was it every programmed by them? Is it a PADLOCK symbol that appears, if it wont TURN OVER then it looks like its not been programmed to the car. Whereabouts in London are you?
    Sep 2010
    London
    Trim : SRI
    Mileage : 45k
    No, the Yellow triangle with spanner flashes. Brentford, Junction2, M4. Chaz
    On the Forum
    346 Post(s)
    Engine : 150
    Mileage : 74000
    i'll be up in Slough monday/tuesday during working hours if u can get there
    11 Post(s)
    Quote Originally Posted by Sierra2 View Post
    Immobiliser fault then.
    The padlock symbol was on earlier Vectras.
    Sep 2010
    London
    Trim : SRI
    Mileage : 45k
    Still works on one key Big Dave?
    11 Post(s)
    Fault with the other key then. The transponder chip isn't being recognised by the car or hasn't been programmed correctly.
    The battery inside the fob is only for the central locking. Under normal circumstances you could remove the fob battery and it will still start the car.
  1. new egr fittment does this need programing in to ecu
    By murf2484 in forum Engine & Drivetrain
    Last Post: 28th September 2012, 20:34
  2. AUX in on CD70 programing
    Last Post: 18th September 2011, 12:01
  3. Problem with BCM programing
    By Agolubovic78 in forum Electrical & ICE (including SatNav)
    Last Post: 18th March 2011, 09:08
  4. Programing issues!
    By colalowe in forum Comedy & Humour
    Last Post: 11th March 2010, 01:28
  5. key programing
    By johnturbo in forum Electrical & ICE (including SatNav)
    Last Post: 13th October 2009, 10:53
vauxhall zafira 1.9 cdti elite 2010 key fobs
