Thread: No power, stranded on holiday
    Apr 2011
    Northamptonshire
    Default No power, stranded on holiday
    On startup this morning my Z30DT idled roughly and won't rev, barely moves in gear (auto). Have started it 4 times, now have engine light on and currently waiting for recovery. I have had a few, maybe 4, occurrences of the car losing almost all power after going over speed bumps at very low speeds, this over last 10k miles, this is first trouble from startup, any ideas as to what could be cause? Last service 1.5k ago by Vx.
    We're at a holiday camp near Clacton, I guess mine could be over now if I have to have the car recovered.
    Ian
    Are you VXR Enough
    13 Post(s)
    Engine : 6.0 V8 Thunder
    have you tried disconnecting the batteryfor half hour or longer. sometimes a reset helps fella hope u get it sorted and it dosnt ruin your holiday
    Apr 2011
    Northamptonshire
    Car is running again, P0093 & P0409 codes showing, RAC chap cleaned EGR and reset codes. I suppose I should now look to replacing EGR in the near future.
    Nov 2010
    East Midlands
    6 Post(s)
    Trim : design
    That's good news - good to see an RAC man who is prepared to get his hands dirty rather than towing you to the nearest garage and dumping you! Got this years subscription back in one. Have a good holiday!
    Regular Member BigWilko's Avatar
    Jan 2010
    Barnsley
    Engine : 3.0 CDTI
    Oops, didn't read the last post
    Quote Originally Posted by iani View Post
    Which one?
    The Car and spanner, in the rev counter, or the orange symbol (that appears before starting the engine, and to the right of the fuel tank warning light)?
    If it is the orange symbol, this is the Emissions Warning light, and almost certainly confirms the EGR is reaching the end of its life
    You can clear this, temporarily, by switching the ignition on and off three times, removing the key and waiting at least three minutes each time (useful if you do not have spanners in the car, to disconnect the battery)
    Unfortunately this removes the active stored code, the warning light will stay on, but it swtiches Safe Mode off
    Mine has just suffered this, and confirmed the EGR valve cannot be cleaned, it is replacement only
    Apr 2011
    Northamptonshire
    Which one?
    Thanks, it was the orange engine symbol, to the right of fuel warning, I'd best get saving I suppose.
    Ian
  1. Signum Sluggish low power, Limp mode at high power.
    By Bigg943 in forum Troubleshooting
    Last Post: 6th June 2011, 18:55
  2. Signum Sluggish low power, Limp mode at high power.
    Last Post: 5th June 2011, 11:30
  3. Off on holiday
    By signumboy in forum General Chat
    Last Post: 5th October 2009, 12:24
  4. XL airways goes into recievership,Tourists stranded!!!
    By glenboy in forum The 'Off Topic' room
    Last Post: 13th September 2008, 11:17
