Thread: normal cdti 150 temp??
    May 2012
    UK
    Trim : SRI
    Engine : 150 CDTI
    Mileage : 124000
    Default normal cdti 150 temp??
    Just wondering whats the normal coolant/temp gauge reading on the 150 cdti engine?
    I've used the search function but read a couple of conflicting opinions, basically, I had my thermostat replaced last week by a mate, my temp gauge now goes up to 86/87 but in stop/start traffic will rise to about 91, on the motorway it will stay at 86/87
    is this normal or could i have some air locked?
    Sodding Typical on Sea
    Sounds very much like mine it sits around the mid 80's then touches 90 in hot days with standing traffic
    Sep 2009
    Glasgow
    same as above
    West
    the actual temp guage is not very acurate... if you have cd70 use the test mode & get the true reading, you will find standing still runs mid to high 90's even when the actual guage is saying low 90's
    May 2012
    UK
    Trim : SRI
    Engine : 150 CDTI
    Mileage : 124000
    thanks for the responses guys
    funny you mention this, I'm sure i noticed my cd70 in safe mode stating 97 but then dropped back down when on the move - i take it this is normal? at what temp reading should i start to worry?
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800 non vvt
    Mileage : 138000
    Quote Originally Posted by elite_150 View Post
    its fine yours is ok same as mine
    May 2012
    NW UK
    Most cars I've had usually sit somewhere about 90° or so for normal running. Yours sounds perfectly normal to me.
    May 2006
    scotland
    I changed my 150 CDti thermostat last Saturday. Prior to this the temperature (digital readout from the CD 30 head unit) was all over the place but generally running approx 70 to 73 C. With the new stat, it takes pretty much the same time to start registering but now sits constant at 84 to 86. Rising very slightly in traffic. Yours sounds very normal as stated above.
    BTW the digital readout and the needle readout are pretty much in unison on my car (obviously the needle is slower to react to change than the digital readout).
    West
    It's percectly normal... as long as the fan kicks in no need to worry
  1. What is the normal running temp of 1.8 VVTi
    By Exclusive BV in forum Vectra C / Signum Car Chat
    Last Post: 8th December 2010, 18:47
  2. CDTI 150, is it normal for it not to smoke ?
    By Vaux-Man-G in forum Engine & Drivetrain
    Last Post: 14th June 2010, 19:12
  3. Whats the normal operating temp when moving?
    By devore in forum Vectra C / Signum Car Chat
    Last Post: 21st March 2010, 18:55
  4. 1.9 CDTi (120) - Normal Operating Temp?
    By vec1975 in forum Engine & Drivetrain
    Last Post: 1st May 2009, 20:10
  5. 'normal' coolant temp
    By Mike57 in forum Engine & Drivetrain
    Last Post: 9th July 2007, 20:27
