Results 1 to 10 of 28
Thread: FOUR WHEEL ALINEMENT..almost
    Regular Member nikroc's Avatar
    Nov 2007
    DERBY
    17 Post(s)
    Vehicle : 2t
    Trim : standard
    Engine : z20net
    Year : 08
    Mileage : 32000
    Default FOUR WHEEL ALINEMENT..almost
    I've just had my alinement done with a hunter system. Sorry I should say I 've had it 3/4 done..rear passenger side wouldnt adjust no matter what the tech tried.
    My query is whats the part called I need to replace??
    Administrator plasma's Avatar
    On the Forum
    405 Post(s)
    Engine : 150
    Mileage : 74000
    it wouldnt pull it into the green or he couldnt undo the nut? You have the 'toe' adujustment, the 'camber' adjustment and caster
    Wondering lonely as a cloud
    26 Post(s)
    Vehicle : M5
    Trim : Nothing needs adding
    Engine : 5.0 V10
    Year : 07
    Mileage : 37000
    Depends what he was trying to adjust mate caster? camber? toe in?
    Edit: just beat me Dean
    Best solution would have been to have the agent highlight (with either blue or yellow paint highlighter) the part they needed to adjust, then drive to the nearest VX dealership and have them identify the part, and order it for you
    Hanging Heaton
    23 Post(s)
    Trim : SRi (VXR Styling)
    Engine : Z19DTH (Re-mapped)
    Mileage : 140k
    It'll be the camber bolt... mine seized when i went, and guy said i was the second that week with same seizure...
    26 Post(s)
    Vehicle : M5
    Engine : 5.0 V10
    Year : 07
    Mileage : 37000
    What is red on your printout?
    Regular Member Damo77's Avatar
    Petersfield, Hampshire
    Engine : 1.9 CDTi 8v
    Year : 55
    Mileage : 92,000
    My guess would be, you would need to buy items 18, 19, 20 and 21 in the following pic......
    Item 18
    11102411
    (Screw, Torx, M12 X 90, Control Arm To Rear Axle, Lower)
    Item 19
    11094488
    (Nut, Hex., M12, Control Arm To Crossmember)
    Item 20 (2 lengths)
    24422973 (Screw And Washer, M12 X 100, Control Arm To Rear Axle, Lower)
    24422972 (Screw And Washer, M12 X 85, Control Arm To Crossmember)
    Item 21
    24428132 (Washer, Control Arm To Rear Axle, Lower)
    __________________________________________________ __________
    Are these the same ones you had trouble with Lee???
    Will be putting in an order for these (providing I've got it right, hopefully someone can confirm???) to Vauxhall as I will be looking at getting a 4 wheel alignment done in the next few weeks after fitting my new tyres, rear upper control arm bushes, rear droplinks and rear anti-roll bar bushes.
    Anybody any idea roughly how much a 4 wheel alignment costs these days?? Neighbour was scaring me with numbers as high as £200-£250 Hope its not that bleeding high
    Damo
    Last edited by Damo77; 6th June 2012 at 03:52. Reason: Spelling and punctuation :-)
    Regular Member dilan's Avatar
    Aug 2009
    dudley, west midlands
    I had hunter alignment done approx 2 months ago and ot cost me £48.....
    Sent from my iPhone using Forum Runner
    Nov 2007
    DERBY
    17 Post(s)
    Vehicle : 2t
    Trim : standard
    Engine : z20net
    Year : 08
    Mileage : 32000
    The print out shows the left rear in the red at -1.26 degrees....
    26 Post(s)
    Vehicle : M5
    Engine : 5.0 V10
    Year : 07
    Mileage : 37000
    Quote Originally Posted by nikroc View Post
    There are 3 figures for the rear toe in/out, caster and camber WHAT was -1.26 degrees all of them or just one when we know what it is we can advise what parts you need to buy
  1. FOUR WHEEL ALINEMENT..almost
    By nikroc in forum Vectra C / Signum Car Chat
    Last Post: 5th June 2012, 21:01
  2. Steering wheel controls..button V roller wheel
    By justin32 in forum Vectra C / Signum Car Chat
    Last Post: 17th September 2011, 18:18
