Thread: scuttle clear but .....
    Regular Member roverjay's Avatar
    Feb 2012
    Skelmersdale
    Vehicle : Vecta
    Trim : sri
    Engine : 1.8
    Mileage : 39000
    Default scuttle clear but .....
    As the title says my scuttle is clear but the carpet in passenger side is soaking wet again , as anyone any ideas were else i can check for leaks
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    Could be the passenger door seal, or even the heater matrix?
    Feb 2012
    Skelmersdale
    Vehicle : Vecta
    Trim : sri
    Engine : 1.8
    Mileage : 39000
    defo not heater the water is clean (doesnt smell of antifreeze) plus no loss in expansion bottle . I`ll have a look at the seal i do know that the little rubber lip that sits on top of the door itself has a slight rip in it but didnt think water would come in through that .
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    It's possible.
    Was the carpet completely dried out after the initial soaking before the scuttle drain was cleaned?
    Might be worth using a pressure-washer around the door and checking for water ingress there and then
    Feb 2012
    Skelmersdale
    Vehicle : Vecta
    Trim : sri
    Engine : 1.8
    Mileage : 39000
    The scuttle was never blocked thats whats got me confused.com Only had car for 7 months so still learning signums lol was previously a omega owner so know all about blockages lol .Might let my little lad loose with the pressure was at the garage .Are there any other common places on the vectra were water comes in
    Jul 2011
    UK
    Year : 06
    Rear arial base if it's perished but can't see water coming from there to footwell
    West
    Check the windscreen/scuttle seal & the little holes on the outside of the scuttle just below the windscreen
    Feb 2012
    Skelmersdale
    Vehicle : Vecta
    Trim : sri
    Engine : 1.8
    Mileage : 39000
    quick update just had glovebox out lifted carpet to dry up the carpet and noticed that were the live wire for the sub comes through the rubber bung i could see daylight lol (this wasnt fitted by me but the previous owner)
    so ive sealed the hole with some sikaflex lol fingers crossed ive cured my leak.
    it looked like the wire was directly below the scuttle drain and was acting as a guide for the water to run straight in
  1. damp smell scuttle clear?????????
    By daddy5times in forum Bodywork & Interior
    Last Post: 22nd January 2013, 19:27
  2. Scuttle removal
    By jrh1 in forum Vectra C / Signum Car Chat
    Last Post: 17th February 2011, 09:09
  3. rear light clusters clear/red/clear
    By Rickiw in forum Parts for sale
    Last Post: 30th July 2010, 15:08
  4. Scuttle Plate
    By Aaron1970 in forum Bodywork & Interior
    Last Post: 5th June 2009, 23:40
windscreen scuttle shield vauxhall
