Results 1 to 10 of 11
Thread: what would cause inside tyre wear?
    Regular Member krazylegz's Avatar
    South Shields
    Default what would cause inside tyre wear?
    Are the vectra C's the same as the B's when you get tyre wear on the inside of the rear wheels, is it usually the rose bushes like on the B's?
    ta
    Assuming, you have just noticed this on the rear tyres only
    This is most likely due to the (incorrect) factory setting of the rear camber
    However have the suspension and steering checked for worn components
    Once these tyres have worn out, bin them (also this will be the cause of increasing noise from the rear of your car), and have a full four wheel alignment carried out
    Compare the rear camber, before and after
    Regular Member Caveman_nige's Avatar
    Jun 2009
    South Coast
    Vehicle : Vectra and a Signum
    Engine : Z18XE,Z19DTH,Z20NET
    just changed my rear bushes yesterday for this very reason mate.. they were less than a year old but knackered already. I replaced them with powerflex bushes this time..
    South Shields
    did you do the trailing arm bushes too or just rose bushes nige?
    Didn't think you could get the rear camber done on these?
    Jun 2009
    South Coast
    i just changed the outer bushes on the upper control arms mate.. You can get bushes from k-mac that allow you to adjust camber..
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800
    Mileage : 133000
    Quote Originally Posted by Caveman_nige View Post
    hi caveman nige
    can i have a link please where you got your powerflex bushes from thanks
    Jan 2012
    Dublin
    Jun 2009
    South Coast
    ebay Item number: 160695343341
    WOLVERHAMPTON
    Worn upper control bushes on mine.
    The rear tyres were shot on the inner edge while the outer had 4mm of tread.
    New arms did the trick.
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800
    Mileage : 133000
    thankyou for info everyone
    thankyou
    thanks
  1. what would cause inside tyre wear?
    By krazylegz in forum Vectra C / Signum Car Chat
    Last Post: 5th June 2012, 23:10
  2. tyre wear
    By fjaimo10 in forum Suspension, Wheels & Brakes
    Last Post: 19th August 2011, 21:43
  3. Tyre wear in rear inside edges
    By lee gsi in forum Suspension, Wheels & Brakes
    Last Post: 8th January 2011, 14:38
  4. wear in inside edge of rear tyres
    By Derek Mc in forum Vectra C / Signum Car Chat
    Last Post: 28th September 2010, 23:45
  5. Help! Front tyres, inside wear!
    By Wiggles86 in forum Vectra C / Signum Car Chat
    Last Post: 27th September 2009, 09:02
