Thread: 56 plate cdti 120 cold and poor starting
    WAKEFIELD
    Default 56 plate cdti 120 cold and poor starting
    Hi all im knew to all this, and until very recently had no problems then had a new egr at xmas ( I GOT RIPPED OFF ) then a new alternator ! ,I now have the following problem if the cars is stood overnight it takes 10-20 seconds to start it before it finally starts in a plume of smoke then it runs fine until its left for a while, it also feels as though its not performing right, ive looked at the other posts and looked under the bonnet but im lost as to the cause can anyone help in pointing me tot he right thread or advice
    thanks
    neal
    Regular Member richy1974's Avatar
    Jun 2012
    leek
    How are your glow plugs when where they last changed when did last change your fuel filter.
    You say u have had a new alternator have you checked your battery.
    VIP-Member Damo77's Avatar
    Petersfield, Hampshire
    Engine : 1.9 CDTi 8v
    Year : 55
    Mileage : 92,000
    Seems as though it could be a multitude of things with the CDTi's
    1. Battery not holding enough charge (Replace)
    2. Starter motor getting slow (Dual Mass Flywheel metal filings blocking it up)
    3. Leak-off pipes
    4. Check all Vacuum pipes all over engine for perishing
    5. Glowplugs or even Glowplug relay
    6. Alternator (You've already changed that)
    7. Fuel filter
    8. Fuel filter housing (known to crack and allow air into fuel supply)
    9. Fuel pipes on top of filter (Blue clips known to work loose/break)
    10. Injectors requiring refurb or replacement
    11. If you've had a newer EGR fitted the 8v 120 may need an ECU software update (Field Remedy 2149)
    I have done most of these things except replace injectors, replace DMF and starter motor but still have intermittent starting issues
    Hope you get to the bottom of it mate
    Damo
    Already replaced:-
    Alternator,
    Drilled/Grooved Discs & Pads, Eibach Springs, EGR Valve, 50W HID's 6000k, K&N Panel Filter, LED footwell & boot lights
    May 2011
    Ashby-de-la-Zouch
    Trim : sri nav/Elite
    Engine : CDTI 150
    Year : 56
    Mileage : 130ish
    my cdti 150 used to be hard to start until i replaced the cam sensor.
    Regular Member C-Owner's Avatar
    May 2011
    South London
    Quote Originally Posted by bigbadcat View Post
    thanks
    neal
    http://www.vectra-c.com/forum/showth...hp-Fault-Fixed
  1. Poor starting.................but not from cold
    By deanos in forum Vectra C / Signum Car Chat
    Last Post: 4th May 2013, 07:32
  2. Poor starting cured (cdti 120)
    By dezzyb66 in forum Engine & Drivetrain
    Last Post: 28th June 2012, 18:56
  3. Poor starting 1.9 CDTI 120 Hot & Cold
    By lehapau in forum Engine & Drivetrain
    Last Post: 4th October 2011, 20:06
  4. poor cold starting CDTi 120
    By bembo449 in forum Engine & Drivetrain
    Last Post: 21st May 2011, 16:53
  5. 03 vectra dti poor starting when cold
    By jono m in forum Engine & Drivetrain
    Last Post: 11th November 2010, 14:16
56 plate vectra cold start problem
vectra 1.9 cdti 8v slow to start
vauxhall vectra 1.9 8v cdti poor starting
