Results 1 to 10 of 13
Thread: car is slower after cleaning the boost sensor!?
    Jan 2012
    Dublin
    Default car is slower after cleaning the boost sensor!?
    I spotted a how 2 on here on how to clean the cdti 150 boost sensor so gave it a go. Mine was solid with gunk when i got it out, got the heavy stuff off with a flat blade screw driver and then blasted it clean with brake cleaner.
    Refitted it and the car drives fine but the hard acceleration has vanished, no longer throws me back in the seat once it hits 2,000rpm.
    What have i done!!?? Have i broken the sensor?
    Jul 2011
    UK
    Year : 06
    U may have damaged the sensor inside the plug
    East Ayrshire
    Trim : SRI XP1
    As above, you may have damaged the little sensor bit in the middle, really shouldnt use a screwdriver on it. See if someone nearby will let you borrow theres for half an hour to see if it makes a difference. I think they're only about £30 IIRC
    Jan 2012
    Dublin
    thats what i feared id done, it was so gummed up that i couldnt sea the wire filament inside so used a screw driver to get the heavy stuff off first which is when i realised the error of my choice! Time for a new sensor i think
    Jun 2011
    Liverpool
    i just used a toothbrush and WD40 to clean my boost sensor
    Jul 2011
    UK
    Year : 06
    Quote Originally Posted by IrishVectra
    I used a little cocktail stick on my mates gently but removed most with the spray
    Regular Member Barlow's Avatar
    Jan 2012
    Chester
    Vehicle : Nissan 350Z GT
    Engine : 3.5 V6
    Year : 06
    Mileage : 50,000
    Think I've broken mine too to be honest. Same as you, I used a screw driver.
    Those sensors ain't cheap either at around 40 squid
    The diagnostic software has the option to test the sensor - haven't tried it yet though.
    East Ayrshire
    Trim : SRI XP1
    It's one of these things, Live and learn. But see if you can try out a mates first. I think theyre the same in the astra and zafira 1.9 aswell. No point throwing money at a problem unless you know its the solution. Hope you get it sorted soon
    Jan 2012
    Dublin
    Live and learn eh guys! Think i'll just fork out for a sensor, pretty sure ive damaged it as the acceleration isnt half of what it was, mind you it still pulls, great engine. Thanks for all the replies
    Sodding Typical on Sea
    I used Methylated Spirits and a small hard bristle paintbrush worked a treat for me
  1. Best method of cleaning boost sensor
    By mutley-k666 in forum Engine & Drivetrain
    Last Post: 2nd November 2012, 03:35
  2. Is there anything I can damage cleaning boost sensor?
    By marky2027 in forum Engine & Drivetrain
    Last Post: 31st July 2012, 14:26
  3. car is slower after cleaning the boost sensor!?
    By IrishVectra in forum Vectra C / Signum Car Chat
    Last Post: 5th June 2012, 18:36
  4. Cleaning Boost Sensor, 1.9CDTi ????
    By mpc in forum Vectra C / Signum Car Chat
    Last Post: 8th July 2010, 23:11
  5. Car still got judder after cleaning egr + boost sensor.
    By bigpaw35 in forum Engine & Drivetrain
    Last Post: 11th August 2009, 18:17
