Thread: 1.9cdti 150
    hioshous
    Default 1.9cdti 150
    need help.
    I looked at the wifes zafira this morning and found a big fluid leak (oil?) coming from the front right corner of the engine. I re moved the battery tray and cleaned it up a bit but it looks like its coming from a connector below the battery tray. Its a fluid line with a quick disconnect on it an a bleed nipple on the back. If I follow the line up through the bay it goes through the firewall at the top right in front of the driver. would this be a clutch or brake or pas connection?. the connector on the engine that the quick connect attaches too is very loose and rattling round in the hole
    cheers
    Sodding Typical on Sea
    Can you post up a pic?
    hioshous
    Looks like the clutch to me! Is the clutch operating fine?
    East Ayrshire
    Trim : SRI XP1
    It's the pressure line for the transmission buddy. If its coming from the end it might just be the retaining clip that needs replaced. Failing that you might need to swap the whole line over
    hioshous
    yes everything is working ok, but the connection is very loose, the clip is missing and its leaking. can you take the plastic connector off the clutch housing without taking off the clutch
    East Ayrshire
    Trim : SRI XP1
    yeah as far as i know. looks like all you need is a new retaining clip for it. Dont know if vx will sell them by themselves tho
  1. vectra 1.9cdti and astra 1.9cdti clutch
    By abz123 in forum Vectra C / Signum Car Chat
    Last Post: 13th October 2012, 21:01
  2. 1.9cdti sri 120
    By dsimpson15 in forum Introduce yourself.
    Last Post: 21st April 2012, 19:24
  3. 1.9CDTI 120 55 reg
    By rjw in forum Cars for sale
    Last Post: 15th March 2011, 15:28
  4. De-Cat 1.9CDTI
    By gregc in forum Diesel Engine related
    Last Post: 26th January 2009, 10:33
