Page 1 of 4 123 ... LastLast
Results 1 to 10 of 36
Thread: Gearbox Drain Plug (F40) ahhhh!!! :( HELP!
    Middlesex
    Trim : SRI
    Engine : CDTI 150 (Z19 DTH)
    Mileage : 100k
    Default Gearbox Drain Plug (F40) ahhhh!!! :( HELP!
    OK - so there was a slight weap on the drain plug so I thought I would remove and give it a new one.
    10 min job NORMALLY!
    Went to undo the drain plug - and will it budge = NO... In the end the T45 socket just twisted in the hole and knackered it!.
    So I have tried:
    Hammering in an oversized T socket = Same result - just twists in the plug
    Hammer a socket on the outer of the plug = Nope - not really enough clearance
    Chisel a grove and then with a bigger chisel try and hammer it off = Nope - just chissels away the metal of the plug!
    So - am out of ideas and now stuck!
    Thinking that maybe a lefthanded thread into the hole where the T fitment once was and then a left handed bolt to that I can do the bolt up in the hole and then undo the plug???
    Failing that - take it to a garage to that they can use the tools I dont have; Welder, heat etc...
    Peeeeed off now!! Never been beaten by a rounded bolt before but these are made of butter!!!
    HELP - ideas?
    A
    Middlesex
    Trim : SRI
    Mileage : 100k
    OK - so thinking these straight down the old T45 (how bigger) hole?
    http://www.amazon.co.uk/Draper-Exper...8894480&sr=1-2
    Are you VXR Enough
    13 Post(s)
    Engine : 6.0 V8 Thunder
    wont your irwin stuff help fella
    Middlesex
    Trim : SRI
    Mileage : 100k
    Nah - no clearance to get them round the outside - plus its a much bigger sized bolt than the biggest irwin tool.
    I think screw extractors are the only way. Failing that someone who can weld a nut on it or something.
    Middlesex
    Trim : SRI
    Mileage : 100k
    South east
    Maybe it's leaked in the past and a previous owner or servicing garage thought the clever thing to do would be to tighten the hell out of it.
    Middlesex
    Trim : SRI
    Mileage : 100k
    Well - got the laser easy outs or screw extractors (what ever you want to call them).. Put the right one in, started undoing and it started tightening in the hole - great all good so far.
    Got it nice and tight - continued to turn it to undo and SNAP! the F'ING screw extractor snaps in the hole!!
    GREAT - its leaking now more than before where I have tried to remove...
    SO - having failed I thought - ill have to book it in somewhere for them to remove it (dunno how)... But then I thought I would call Mr Clutch in SL where I had the clutch done. Spoke to Dan and he said - ahhh no problem, bring it to me in the morning and ill get Dave (workshop foreman) to chisel it straight out... I did mention that I had tried that and he told me not to worry - bring it in and he will have it straight off!!
    Slightly happier - will be more so when its off tomorrow!
    Another PLUS for Mr Clutch in Slough!
    Jan 2012
    Milton keynes
    Trim : M Sport and Design
    Mileage : 38100
    Watching this with thread with interest! Good luck!
    I guess when it gets to this point, could something just be welded on to it?
    Middlesex
    Trim : SRI
    Mileage : 100k
    Quote Originally Posted by Chunklamb View Post
    TBH that was my next step. Go to a garage to gt a nut or something welded to it - lets see if Mr Clutch will buge it.. I tried the chisel method - but just kept eating into the metal of the plug... Maybe my chisel was too sharp! lol...
    Let you all know - A
    Regular Member CH-VECTRA-ELITE's Avatar
    Frimley
    Mileage : 140000
    Hope is doesn't leak to much to effect the gearbox
  1. :( So Fed Up - Gearbox spat out the drain plug!!!!
    Last Post: 12th July 2012, 09:28
  2. Gearbox drain plug leak
    Last Post: 18th June 2012, 18:19
  3. auto gearbox drain plug
    By bert01909 in forum Engine & Drivetrain
    Last Post: 19th September 2011, 18:14
  4. gearbox drain plug
    By collyb in forum Engine & Drivetrain
    Last Post: 3rd May 2011, 13:47
  5. Gearbox oil drain plug
    By big nath in forum Engine & Drivetrain
    Last Post: 15th February 2011, 18:13
