Thread: cd70 no bc
    Regular Member Nessy's Avatar
    Jul 2009
    Leeds
    Default cd70 no bc
    just bought a 05 vectra sxi it has the cd70 fitted sat nav works stereo works can enter test mode but it seems the bc function isn't doing anything it just goes to a timer :s
    how can i get this part going ?
    seems i have no check light on the left dial on my dash for bulbs out n stuff so I'm presuming it shows up on here when its working correctly
    any help appreciated
    Engine : 1.9 CDTi
    It's an option that needs to be enabled with Tech2 or other type software.
    Regular Member wardy23's Avatar
    Nov 2011
    North Yorkshire
    Vehicle : vectra
    Trim : sri
    Engine : 2.2
    Mileage : 64000
    if someone can pm me the info on how to activate it for him im more than willing to do it if he travels to normanton
    Jul 2009
    Leeds
    That's really sound of u mate I have no idea what this needs or how to go about it from what I've read today vx dealers don't do it they just fob u off I did find this but it's from an Astra forum
    Just got my BC enabled today on my 1.9 CDTI 57 plate Design via Tech 2. The guy said it couldnt get done as the option he got said attention and then not available, but eventually got BC enabled but thanks to the AOC and AON forums i found a post that had instructions to enable it and i showed the guy and he got it going.
    These instructions weren't 100% as they missed out a few steps but this is what I gave to guy at Autovaux who got my BC working.
    1, tech2 screen, ENTER
    2 diagnostics
    3 year of car eg 2007
    4 astra h
    5 infotainment
    6 programming
    7 code index
    8 program code index
    9 enter
    10 a part number will flash on the screen press enter
    11 the type of set up will flash on the screen eg liniar resistance type b press enter
    12 current code index is displayed eg code index 009 version 3
    press program
    13 change code index to 008 if original index is 007 or 010 if original is 009
    14 press program
    15 programming is complete press finish/abort
    16 exit to main screen and turn off
    Not sure if this is relevant or not. I presumed this would just be enabled on a second hand motor.
    Jul 2009
    Leeds
    can anybody else confirm this is the right method to activate bc on a vectra if not wat is the right one
    cheers
    11 Post(s)
    Quote Originally Posted by Nessy View Post
    It depends. BC is only for the fuel computer, not the Check Control system which would give you the info in the stereo display. Pretty sure an SXi doesn't have Check Control.
    At some point Vauxhall moved the bulb failure warning light from the rev counter display to near to the door and boot open light at the top centre of the speedo binacle. Why not try taking a bulb out of the rear light cluster and see if it comes on.
    Jul 2009
    Leeds
    yea il do that its defiantly not coming on for the door and boot open il take a bulb out see what happens... its just when u look closely when the cars switched off the square on the rev counter looks more dull or matt than the one on the mph so i just presumed this wasnt a light at all on the sxi and the check control was part of the centre screen so if it doesn't light up when a bulb is out and its not part of the bc where is my check control ?
    Engine : 1.9 CDTi
    Check control is also a function that can be enabled.
    PM Wardy as he may have whet he needs to program the BC and check control now.
    Jul 2009
    Leeds
    when i hold down my settings button for 10 seconds and it goes to the info pages it says my code is set to 010 ver 1 so do i need that changing to 011 or not ?
    i can see when i go to the page for bc everything is off as is the check control page
  1. CD70 and Aux in
    Last Post: 8th January 2013, 13:59
  2. Cd70 please help!!! :)
    By jones5n in forum Electrical & ICE (including SatNav)
    Last Post: 22nd June 2011, 10:34
  3. Cd70
    By gregc in forum Electrical & ICE (including SatNav)
    Last Post: 11th November 2010, 02:32
  4. cd70
    By wstwatson in forum Vectra C / Signum Car Chat
    Last Post: 22nd June 2009, 20:51
