Results 1 to 10 of 23
Thread: Urgent Help needed please, 150 belt broken
    Regular Member Mopar Man's Avatar
    herts
    Default Urgent Help needed please, 150 belt broken
    Hi
    I have a 1.9 150 with water pump failed. I am fitting the new belt back on and havnt got the genuin belt with marks as VX are closed. The crank is lighned up with marks, but the cam has no pointer, like the 120 has? I have no locking pins and want to see a pic of a cam pulley position when crank marks are lighned up. Thanks
    Sep 2011
    lewes
    Engine : 1?? - Teapot mapped
    Mileage : 125000
    Why don't you just read my answer in the other thread?
    herts
    I did, but that is no help as the belt has moved and cant make my own marks????
    Sep 2011
    lewes
    Mileage : 125000
    Belts marks are not necessary otherwise all belts would have them, plus after one rotation of the engine they won't line up again. The two marks you need are the crank pulley which you've aligned, and then just make your own on the cam pulley and casing, use some tippex. Fit the belt - start around crank then up to cam keeping that bit taught then fuel pump pulley, tensioner and finally water pump. Check the pulleys haven't moved by the marks, tension and rotate engine twice. Your pulley marks will or should be in the same place and line up. Job done
    herts
    Why is there no pointer on the 150 engine??????
    Golfpro the belt has moved as said, so how can i make my own marks?????????
    herts
    I thought someone would be able to help me on this? Im now going to have to strip my mates car to find out where the cam pulley should be. A lot of work just for this. Im going down the garage in 30mins.
    Sep 2011
    lewes
    Mileage : 125000
    I am helping you. You are just choosing to ignore it. Leave you to it
    Nov 2010
    East Midlands
    Trim : design
    'Why is there no pointer on the 150 engine??????'
    ? Why do men have nipples - your supposed to make the marks on the camshaft pulleys and a fixed point on the block/ head casing when the old belt is still in place which in effect gives you the original settings. You Thread title says the belt was broken - in which case you can't use the old settings - although your text says the water pump has failed!
    Engine : 1.9 CDTi
    I think you will need the timing tool as it locks the crank in a different position and then the cam marks line up.
    Have a look at the tool instructions: http://www.tooled-up.com/artwork/ProdPDF/VS4775.pdf
    Regular Member hairytimes's Avatar
    Apr 2012
    norwich
    if the pump failed with the car running did it "hit" have u repaired the damage caused?
    if u have u need to time the whole thing up. put piston one on tdc then cam pulleys on there timing marks ???
  1. Broken drivers seat - Urgent
    By SamT in forum Bodywork & Interior
    Last Post: 14th August 2012, 17:18
  2. Urgent help please, whats broken??
    By LEW1S2006 in forum Vectra C / Signum Car Chat
    Last Post: 30th January 2010, 18:53
  3. Cam belt change urgent question
    By andreitone in forum Engine & Drivetrain
    Last Post: 5th November 2009, 17:05
  4. Urgent Help!! Fan/auxilliary belt fitment
    By buggy_666 in forum Engine & Drivetrain
    Last Post: 28th September 2008, 16:05
  5. Urgent....Belt tensioning bolt
    By JSM414 in forum Engine & Drivetrain
    Last Post: 9th October 2007, 21:34
