Thread: Wishbones
    Regular Member FatboySteve's Avatar
    Bedfordshire
    Default Wishbones
    Well, my wishbones need doing...AGAIN. I got a bit over 12 months (15-20k miles) out of the cheaper autovaux ones. (similar price to ebay at the time)
    From observation, there seems to be 2 price ranges for these, around £50 and well over £100 for genuine (and sometimes not) ones, my question is, is there any difference between these ? will the genuine actually last that much longer ? as i don't really want to be replacing them every 12 months!!
    I've looked at the powerflex bush kits which seem quite well priced, but in my experience it's the ball joint which gets damaged most, and these don't appear to be replaceable serperately, unless someone can tell me otherwise, so it seems pointless putting good bushes in if the ball joint is just going to go anyway!
    So, looking for others experience, and what they have done
    Regular Member Sebastian's Avatar
    Electric Heated Recaro Leather
    38 Post(s)
    Engine : 1.9 DTH
    Get lomferder ones from ECP or try get genuine ones .... ECP ones around 100£ but in the end of the day undo get what u pay for.... Genuine ones last 100 k + so you do the math
    HTH
    Regular Member Damo77's Avatar
    Petersfield, Hampshire
    Engine : 1.9 CDTi 8v
    Year : 55
    Mileage : 92,000
    Not sure if anyone has tried replacing the bushes on the front wishbones but for the price alone I'd be willing. Had a look at Powerflex's website and it looks as they do bushes for the Front and Rear mounts on the Front Wishbones
    http://www.powerflex.co.uk/products/...29-2690/1.html
    Looks as though items 1 & 2 are for the Front Wishbones and when you cost them together it works out to be £56.28 per wishbone and from what I've heard Polyurethane bushes are supposed to be the biz
    Will be going down this route when I get the opportunity and might get the rear upper control arms done (even though they are closer to £100 per side) when funds allow
    As you have already mentioned though it seems as though the ball joint is not replaceable so I'm guessing the wishbone would ultimately need to be replaced
    Good luck getting it sorted,
    Damo
    It's true you can't replace the wishbone lower ball joint and that's the part that takes 90% of the abuse , I changed near side wishbone last week and will be changing the off side tomorrow
    I paid £40 for each one and if they last a year I'll be happy it's only a 20 min job to change them
    The world famous city ground
    Vehicle : Vectra cdti estate
    Trim : Get a
    Engine : Dirty diesel
    had to change my nearside wishbone for my MOT and also recently changed a mate's nearside one due to the ball joint failing...
    both cost around the £65.00 mark each and were brought from different places
    Regular Member XPCobra's Avatar
    Dec 2010
    Glasgow
    Vehicle : Vauxhall Vectra Hatch
    Trim : SRI with added X-Pack
    Engine : 1.9 16v 150
    Mileage : Near 100K
    Balljoints failing within 15K miles? Are you bumping up and down kerbs constantly?
    Bedfordshire
    No, just lots of crappy B roads with bad surfaces
    Thanks for all the info guys
  1. New wishbones ordered
    By sheepish in forum Vectra C / Signum Car Chat
    Last Post: 22nd November 2013, 23:13
  2. front wishbones
    By mjsvinyl in forum Vectra C / Signum Car Chat
    Last Post: 17th November 2010, 00:38
  3. wishbones
    By tj56 in forum Vectra C / Signum Car Chat
    Last Post: 30th April 2010, 09:21
  4. Wishbones
    By nikroc in forum Suspension, Wheels & Brakes
    Last Post: 20th October 2008, 13:15
  5. Front wishbones
    By cpt slow in forum Suspension, Wheels & Brakes
    Last Post: 28th March 2006, 21:01
