Results 1 to 10 of 18
Thread: Vectra 1.9 CDTi 150 Alternator / battery voltage
    Regular Member trucklord's Avatar
    Jun 2012
    Retford , Notts
    Red face Vectra 1.9 CDTi 150 Alternator / battery voltage
    Hi There
    Can anyone tell me what the correct voltage the alternator should be charging the battery to please.
    Volt tested my battery today and it was just over 13v ( about 13.2 ) on the needle.
    I have a slight rattle / tickticktick noise coming from the alternator area, ( and putting a LONG bar on the altetrnator housing and listening to it at the end you can hear what sounds like a dodgy bearing ? in there )
    Would this voltage be enough to cause a very intermittent power steering loss when i start the car ?
    Thanks in advance folks.
    Eric
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    12.5 +/- .2v from battery
    14.4v from alternator no load
    An roughly 13.9v with lights heaters etc on
    Hope that helps
    PRESTON
    The tick tick noise is probably the overrun pulley, but if the alternator is not putting out 14 volts as said above, it's probably on the way out.
    Nov 2010
    East Midlands
    Trim : design
    Hi Eric,
    Is 13.2 what your battery is reading without the engine running - that seems a little bit high for the battery - with the engine running the alternator should be putting out about 14.4 volts - I wouldn't think that the readings you have would stop the power steering operating but loss of power steering is a classic sign of alternator failure on that engine
    Sorry Critch yours went on as I was typing!
    Jun 2012
    Retford , Notts
    Thanks folks.
    I only tested from the battery whilst the engine was running 13.2v. Even revving didn't alter it.
    Havent tried it with the lights / heater on etc.
    will try again asap - borrowing a multimeter to check digital readout.
    Only had the car a week but already lots of thing to sort out.
    The How 2 section on here is a goldmine !
    To do: EGR blanking plate
    swirl flap bar £1 fix - currently all shiny on my sideboard.
    swirlflaps 1,2,and 4 just vibrating round and round coughing crud all over the place.
    power steering.
    wirral
    59 Post(s)
    Trim : Basic
    Engine : 1.9
    13.2 running with no change is a dead. Well fighting for life alternator so that needs to be added to list aswel
    Jun 2012
    Retford , Notts
    have just planted the money tree, hope it comes to fruition soon.
    Really wish my BMW hadnt blew up last week, now got 2 cars on the drive to fix.
    Its all coming back to me why i swore never to have another vauxhall 5 years ago...
    Nov 2010
    East Midlands
    Trim : design
    Quote Originally Posted by trucklord View Post
    Well it looks like you will get plenty of rain for your money tree - If it helps I replaced my alternator and bought it from http://www.ebay.co.uk/itm/VAUXHALL-V...#ht_530wt_1037 - (make sure you have the Denso alternator and not the Bosch, which is slightly different - but they can supply both types) fitted it well over 12months ago to my 1.9 cdti (120) and never had a problem - I've had three off them for other cars and all fitted and work fine, as well as a couple of starter motors. I am not connected with the business - but have always had good,friendly service and if you contact them saying you need the part urgently they will usually deliver next working day. Hope this helps a bit.
    Regular Member Sebastian's Avatar
    Electric Heated Recaro Leather
    38 Post(s)
    Engine : 1.9 DTH
    Funny u say that about denso I had fitted denso replacement and lasted exactly 13 months and then smoked itself to death...
    fitted bosh one which is bit smaller and easier to fit never looked back
    Nov 2010
    East Midlands
    Trim : design
    Hi - I wasn't recommending Denso - just saying there are two types fitted and I understood they were a different fitting - but obviously if you replaced a Denso with a Bosch they must be the same fittings. The one this guy supplied to me was not a genuine Denso alternator but a Denso type and I have no complaints (so far).
  1. What voltage should the alternator be producing (3.0 V6 CDTi)?
    By ph67 in forum Electrical & ICE (including SatNav)
    Last Post: 25th January 2013, 14:37
  2. 3.2 - alternator voltage fluctuates
    By Jay-C in forum Electrical & ICE (including SatNav)
    Last Post: 1st November 2012, 14:14
  3. Vectra cdti battery/alternator problem help
    By goooba769 in forum Vectra C / Signum Car Chat
    Last Post: 5th March 2011, 11:17
  4. Alternator Voltage
    By Godzilla in forum Engine & Drivetrain
    Last Post: 10th June 2010, 21:47
  5. 05 cdti (120) alternator and battery swap?
    By longtings in forum Engine & Drivetrain
    Last Post: 16th June 2009, 16:27
vectra 1.9 cdti alternator
vectra c alternator problems
vauxhall vectra alternator problems
vectra cdti alternator or battery
https:www.vectra-c.comforumshowthread.php165489-Vectra-1-9-CDTi-150-Alternator-battery-voltage
alternator denso vectra c
vauxhall vectra 1.9 cdti alternator problems
2007 vauxhall astra 1.9 cdti alternator problems
vectra 1.9cdti 150 alternator
types of alternators fitted to vectra c
vectra c 1.9 cdti alternator output
vectra 1.9 c alteenater
vectra c voltage display
alternator zafira b 1.9cdti amps
zafira alternator check
vectra c signum normal voltage
vectra c alternator output
vectra c 1.9 cdti alternator problems
vectra c different alternator
low voltage vectra c 1.9 cdtibattery voltage vectra cvauxhall vectra 1.9 cdti sri alternatorvectra c alternator voltage regulator densowhat voltage should a battery be running at zafira 1:9Vauxhall 1.9 cdti battery charge
