Thread: signum intermittent blue smoke and weird temp gauge
    May 2012
    yorkshire
    confused signum intermittent blue smoke and weird temp gauge
    ive recently got a signum 1.9cdti however something really weirds been happening the temp gauge drops from 85 to 0 then it starts smoking out of the exhaust but if you turn of the car and restart its ok this seems to only happen when its being driven standing ticking over it never does it no matter how long its stood please help
    Mar 2012
    wakefield
    Vehicle : vectra v6 cdti
    Trim : sri
    Mileage : 70000
    How long does it blow smoke out,after a couple of weeks of getting my siggy it started to run rough and blow abit of smoke out so i turned engine off and straight back on and it would run great again for a day or two but then would run rough again and smoke,after reading on this site i learned the car was trying to do a regen so when it happens now i rev it at 2000 rpm for around 5 to 10 mins until it clears and now no probs,not sure about temp gauge as mine is allways on zero.
    May 2012
    yorkshire
    thanks its blue smoke and only happens when temp drops to nothing
    May 2012
    yorkshire
    thanks its blue smoke and only happens when temp drops to nothing sorry forgot to mention a soon as it starts smoking it doesn't
    stop unless i turn it off also when dpf is doing a regen i thought th glow plug warning light was supose to flash
    Mar 2012
    wakefield
    Trim : sri
    Mileage : 70000
    No i dont think they do flash anymore,i heard that when they first came out people where taking their motors back to the dealers thinking something was wrong when the glowplug light flashed so vauxhall did away with it,the dpf is supposed to stop smoke i only see smoke on mine when its doing a regen,as yours still got the dpf fitted
    May 2012
    yorkshire
    yes so many people are saying turbo seals,valve guide oil seals,piston rings etc surely it cant be any off these as it would do it all the time
    Jun 2012
    yorkshire
    Default blue smoke
    Quote Originally Posted by kevsmit View Post
    Hi did you find the cause of the problem ?
    as i have the same fault just accured on mine.
    Thanks kev
  1. intermittent blue smoke
    By rec in forum Engine & Drivetrain
    Last Post: 9th July 2012, 19:23
  2. signum intermittent blue smoke and weird temp gauge
    By kevsmit in forum Vectra C / Signum Car Chat
    Last Post: 5th June 2012, 21:08
  3. signum intermittent blue smoke and weird temp gauge
    By kevsmit in forum Engine & Drivetrain
    Last Post: 2nd June 2012, 20:54
  4. Weird temp, gauge behaviour ?
    By eeyore in forum Vectra C / Signum Troubleshooting
    Last Post: 14th December 2011, 16:24
  5. signum 2.0t coolant loss and faulty temp gauge
    By catbic in forum Engine & Drivetrain
    Last Post: 25th July 2011, 09:42
vauxhall nott
