Thread: wheel spacers
    Regular Member decks's Avatar
    Apr 2008
    nothern ireland
    Vehicle : 2.0t btcc
    Default wheel spacers
    would this wheel need spacers with 235-45-18 tyres http://autoalloys.com/index.php?rout...product_id=136
    Regular Member hairy31's Avatar
    Jun 2009
    bradford
    what makes you think it wil need spacers? you could fit spacers if you wish but not thought they would be a must
    Apr 2008
    nothern ireland
    Vehicle : 2.0t btcc
    thinking about spacers as the same site said you will be fine from et 35-43 these wheels are et45
    Regular Member 4ndy's Avatar
    Oct 2010
    Glasgow
    You'll be fine with that offset but the 45mm profile will put the speedo out. 235/40/18 is the correct size for those wheels.
    Regular Member Hummelshøj's Avatar
    Aug 2009
    Denmark, Kolind
    Vehicle : Vectra C OPC Estate
    Trim : OPC / VXR
    Engine : Z28NET
    Quote Originally Posted by greenleprechaun View Post
    I think you are mixing the numbers a little up..
    He is talking ET45 on a wheel and you are talking 45 profile on tires.
    Let´s not confuse the guy more than we have to..
    Oct 2010
    Glasgow
    Quote Originally Posted by decks View Post
    Quote Originally Posted by Hummelshøj View Post
    His post at the top clearly says: would this wheel need spacers with 235-45-18 tyres and the link takes you to VXR replicas with an offset of 45mm.
    Aug 2009
    Denmark, Kolind
    Trim : OPC / VXR
    Engine : Z28NET
    Sorry.. my mistake..
    Apr 2008
    nothern ireland
    Vehicle : 2.0t btcc
    so if i go for tyre profile 235-40-18 i wont need spacers on et45 offset
    Hanging Heaton / Batley
    19 Post(s)
    Trim : SRi (VXR Styling)
    Engine : Z19DTH (Re-mapped)
    Mileage : 110k
    You won't need spacers anyway, the C takes up to 45 offset...
    The 45 tyres make the circumference of the tyre larger throwing your speedo out.
    Oct 2010
    Glasgow
    Quote Originally Posted by leemarksmith View Post
    The 235/40/18 tyre profile is the best size match for speedo accuracy and fills the arches nicely with a decent amount of rubber to protect the rims. Some go for the cheaper 225/40/18 which are the tyres fitted to mine but they are slightly too small and don't look at all standard.
    I can't wait until mine need changed so that I can get the 235/40/18 instead.
  1. Wheel spacers ,yes or no?
    By pogo in forum Vectra C / Signum Car Chat
    Last Post: 6th February 2013, 12:40
  2. wheel spacers , has anyone?
    By melvyn8181 in forum Styling
    Last Post: 12th October 2011, 10:26
  3. wheel spacers
    By hairy31 in forum Handling & Braking
    Last Post: 27th June 2010, 14:33
  4. wheel spacers ? should i fit them?
    By pogo in forum Suspension, Wheels & Brakes
    Last Post: 19th January 2010, 21:44
