Results 1 to 10 of 27
Thread: Tyres Cracking On Edges
    Regular Member Ralphwells1967's Avatar
    dartford
    Default Tyres Cracking On Edges
    Afternoon noticed some cracking on the outer edge of both my bridgestone runflats, was wondering if i've any thing to worry about like will i need to change them ? sorry pic aint brilliant was taken on me phone
    WGAF#5
    What's the date stamp on the tyres ??
    They are runflats, so I am not surprised (especially if they are 18" or larger)
    What is the tyre pressure they are supposed to run at, and what are they currently?
    I assume you have TPMS fitted
    What specification are the tyres?
    dartford
    Dez i wouldn't even know where the date stamp is m8 lol and m8 no TPMS i check pressure every morning running 43psi at mo ,well not to good with technical stuff lol well what ya recon the sha**ed or not ? lol
    Quote Originally Posted by Ralphwells1967 View Post
    Usually easy to spot
    It is a four digit code, so should end 08, 09, 10, 11, or 12
    I would highly recommend NOT purchasing RFT specification tyres, even if you are checking the tyre pressures daily
    The main issue, as many BMW owners are reporting, is they are much harder when compared to standard tyres
    As a result many such owners go back to standard tyres and report the difference is well worth it (plus cheaper too)
    running 43psi at mo
    That's incredibly high
    Any reason for that?
    Regular Member Mr Owens's Avatar
    Jun 2012
    Wickford
    Trim : Sri
    Engine : 2.2 direct
    They shouldn't be much more than 30psi at that pressure I'm supposed they haven't worn to the limit in the centre of the tyre
    running 43psi at mo
    As above, would need to know the exact tyre size (or at least the wheel size)
    However, even with 19" wheels shouldn't be more than 43 front / 39 rear (V6 engines) or 38 front / 33 rear (all others)
    Finally, what tyre is that position in? (nearside / offside, front or rear)
    Quote Originally Posted by Mr Owens View Post
    eh, PSI is pressure...
    The tyres on my car are 39 front / 35 rear, and others (V6 and 1.9CDTI) will be very near to that, and certainly more than 30
    Almost all the others are at least 32 to 35
    Jun 2012
    Wickford
    Trim : Sri
    Engine : 2.2 direct
    The majority of cars on the road run at about 32psi front and 30psi rear 39psi is far too much pressure that's what you would put in a van
  1. For Sale: Full Set of Dash Vents - Facelift Surround (rounded edges)
    Last Post: 13th June 2012, 11:18
  2. Tyre wear in rear inside edges
    By lee gsi in forum Suspension, Wheels & Brakes
    Last Post: 8th January 2011, 14:38
  3. Replies: 12
    Last Post: 31st July 2010, 13:07
  4. I'm cracking up
    By bigbnlr in forum Vectra C / Signum Car Chat
    Last Post: 9th December 2009, 19:27
  5. Cracking up!
    By joules2.0t in forum Electrical & ICE (including SatNav)
    Last Post: 5th March 2007, 18:33
