Results 1 to 3 of 3
Thread: fuel filter dripping cdti
    May 2012
    UK
    Trim : SRI
    Engine : 150 CDTI
    Mileage : 124000
    Default fuel filter dripping cdti
    Hi
    Hoping someone can help...
    when the engines running i've noticed steady dripping of diesel from the fuel filter - what do I need to tighten to stop this? i think its coming from the top
    engine: cdti 150
    Nov 2010
    East Midlands
    Trim : design
    Check the push in fuel pipes - one on the top and another slightly lower - if its not one of them it could be the lid itself - check that the large tightening ring is tightly screwed down. There is a large rubber sealing ring insde there that should be compressed by the lid against the main body by tightening the locking ring. The filter bodies have also been known to split and leak so check carefully.
    Regular Member Chris B's Avatar
    Jan 2012
    Essex
    Have you recently changed the filter?
    When I did mine leaked with the new gasket fitted, put the old gasket back in and its fine, quite tough to do up tight though!
  1. Oil and fuel filter 1.9 cdti 150
    By chay6684 in forum Vectra C / Signum Car Chat
    Last Post: 10th May 2012, 08:07
  2. Where is fuel filter on 3.0 V6 cdti
    By s2yob in forum Vectra C / Signum Car Chat
    Last Post: 23rd June 2011, 17:29
  3. Cdti fuel filter
    By winnie2457 in forum Engine & Drivetrain
    Last Post: 3rd September 2010, 21:06
  4. cdti fuel filter
    By cockney16v in forum Vectra C / Signum Car Chat
    Last Post: 25th February 2010, 19:23
  5. CDTI Fuel filter
    By crgv6 in forum Engine & Drivetrain
    Last Post: 26th November 2009, 21:27
