Results 1 to 10 of 24
Thread: HELP - front charger removal to replace with ciggy lighter
    Regular Member hairy31's Avatar
    Jun 2009
    bradford
    Default HELP - front charger removal to replace with ciggy lighter
    as above guys, how the heck do you remove the charger socket without breaking anything....pics would be nice.
    Full Member Niall83's Avatar
    Nov 2009
    Belfast
    I wasn't able to remove it, maybe the whole surround comes off but I felt the same as you for fear of breaking it when pulling.
    AirBox Mod-Angel Eye head lights-HID 5000k-Colour coded grill-GID to CID-Auto Dim rear view Mirror, Rear Parking Sensors, Signum Fog surrounds, 19" Audi A5 rep Alloys, Eibach 30mm Pro-kit Lowering Springs.
    Northern Ireland Region trip to Knockhill 2014
    Jun 2009
    bradford
    Just spent twenty mins trying....I'll forget it also lol
    morecambe
    28 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    Hammer and chisel lol
    Jun 2009
    bradford
    Quote Originally Posted by paulvectrac View Post
    your no help are ya mate
    Wirral, UK
    Vehicle : Meriva B
    Trim : SE
    Engine : 1.7CDTi
    Year : 2011
    The trim around the ciggy lighter comes off first (carefull, try not break the tabs), then remove the ashtray completely, then the ciggy lighter comes up away from the illuminated ring so you can remove the ciggy lighter light, then the illuminated ring pulls out.
    Jun 2009
    bradford
    Quote Originally Posted by TonyP2020 View Post
    erm I beg to differ mate...........all the trim comes off - but the lighter will not budge either up down twist etc etc............but thanks for the reply
    Jul 2011
    UK
    Year : 06
    Tale all trim off and ashtray get under the lighter and push it up it's very tight and hard to get it out but does come
    kirriemuir
    i found if you push from the bottom slightly twist it i think if i remember right it has two small plastic tabs on the surround that holds it in place
    Regular Member John Bishop's Avatar
    Oct 2010
    Take trim from gearstick surround off, then remove ashtray insert, then remove ashtray. Remove storage compartment above ashtray this makes it easier to get your hands in as the socket is tightr to get out. Then remove trim around socket. Push metal housing up and unplug and finally remove socket trim.
  1. ciggy lighter
    By The Gas Man in forum Vectra C / Signum Car Chat
    Last Post: 17th June 2010, 23:54
  2. Ciggy lighter
    Last Post: 9th September 2009, 22:41
  3. ciggy lighter help
    By Clugie in forum Electrical & ICE (including SatNav)
    Last Post: 7th September 2009, 17:31
  4. Ciggy lighter dead
    By APJ in forum Electrical & ICE (including SatNav)
    Last Post: 31st October 2007, 12:15
  5. ciggy lighter
    By m20_swe in forum Vectra C / Signum Car Chat
    Last Post: 30th October 2006, 21:29
remove of trim under gid on 06 vectra
