Results 1 to 10 of 13
Thread: Air Bag mot
    Oct 2007
    nottingham
    Default Air Bag mot
    Hi
    I have 2 blown air bags,nearside seat and curtain airbag.
    Have done some reseach and think i can repair this myself,curtain airbag 25 pounds of e-bay send away airbag module for repair 30 pounds,i have access to tech 2 .
    Anyboby got any advice on doing this job,air bags blew 6 years ago when i hit some black ice.
    thanks
    Tommy
    May 2011
    Ashby-de-la-Zouch
    Trim : sri nav/Elite
    Engine : CDTI 150
    Year : 56
    Mileage : 130ish
    do you mean deployed? i have both front seat air bags you can have for free Nottingham isn't far from me.
    Oct 2007
    nottingham
    Quote Originally Posted by dan danz View Post
    Thanks for your offer Dan very kind but i already have the seat airbag,bought it long time ago,did cost me about 80 quid though yes the airbags were deployed they go with a big bang,not one of my better days,
    Tommy
    Engine : 1.9 CDTi
    Some airbag ecu's can be reset with other Tech2 type software (I have done it to a MK5 Astra)
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    If its same as Astra then air bags are easy to replace and can be reset using tech 2
    May 2011
    Ashby-de-la-Zouch
    Engine : CDTI 150
    Year : 56
    Mileage : 130ish
    made a big bang i might set my spares one off then and record it for youtube
    Oct 2007
    nottingham
    Does anybody know if i will need a new airbag senser?
    Thanks Tommy
    Engine : 1.9 CDTi
    Without knowing what codes are stored you cant tell.
    Oct 2007
    nottingham
    Thanks Lee they are on e-bay for a tenner so could just get one anyway
    Tommy
    Jun 2009
    South Coast
    Vehicle : Vectra and a Signum
    Engine : Z18XE,Z19DTH,Z20NET
    make sure you get the correct airbags, some have a single connection and some have a two wire connection.. I should think you need to change you seat belt pretensioners as well, these are also in twpo different types (a single connector version and two connector version). The G shock sensors (impact sensors) may also need to be replaced.. If you do a full tech2 readout or use the other software it will tell you what you need to replace along with getting the deployment data wiped from the ecu..
