Thread: Cam breather pipe - Gas temperature?
    Hanging Heaton / Batley
    19 Post(s)
    Trim : SRi (VXR Styling)
    Engine : Z19DTH (Re-mapped)
    Mileage : 110k
    Default Cam breather pipe - Gas temperature?
    What temperature is this likely to get to once engines fully warm?
    Im going to build a custom pipe to my TB shortly, I'm still going to have the cam vent into it but just curious? Might flip the entry point round and extend the pipe to a catch can? Don't fancy putting just a breather as want to keep pressure down...
    So what we talking? It's about a 30cm pipe on the 2.2 at min, is it likely to be in the high 50's or more so that's getting dumped straight back into the TB essentially?
    19 Post(s)
    Mileage : 110k
    Shall we all guess till someone confirms, I'll go first
    70'c... Ha
    The pipe or the gas?
    You could construct a relief pipe and attach it, to then establish what the gas temperature is
    Presumably you really mean the crankcase breather pipe
    I would estimate in the region of 80'C (40' above ambient temperature)
    19 Post(s)
    Mileage : 110k
    Sorry yeah the gas temp... So we chase cold air feeds then this is just dumping it back in, albeit a small percentage of what comes through the TB intake pipe.
  1. Clear Cam Breather Pipe
    By Leemarksmith in forum Engine & Drivetrain
    Last Post: 9th June 2012, 14:43
  2. Crank case breather pipe?
    Last Post: 27th May 2012, 22:00
  3. Breather pipe
    By Governor in forum Diesel Engine related
    Last Post: 22nd June 2011, 12:40
  4. oil breather
    By Matt&Jemz in forum Petrol Engine related
    Last Post: 31st July 2010, 14:38
  5. oil breather
    By Dougb in forum Engine & Drivetrain
    Last Post: 8th May 2010, 18:10
