Thread: Dash illumination? Volts & fuses?
    Hanging Heaton
    23 Post(s)
    Trim : SRi (VXR Styling)
    Engine : Z19DTH (Re-mapped)
    Mileage : 140k
    Default Dash illumination? Volts & fuses?
    Do all the dash LEDs run from the same fuse, if so what size and number in the box?
    Also as the SMD's are low power is it a 12v feed, don't have a voltmeter
    Regular Member ScotsDragon's Avatar
    Aug 2009
    Lost in Time and Space...
    Trim : SRI
    Engine : 1.9 CDTI 150
    Mileage : 50000
    Most leds are low voltage, Red + Green+ Orange 2-3V and blue + white 3-4V, I was looking for a similar circuit and was thinking that the dash dimmer must be part of the voltage control for the leds, If you find anything out please let me know.
    Hanging Heaton
    23 Post(s)
    Mileage : 140k
    Thats what i was thinking or they wouldn't dim... Anyone got a voltmeter and fancy testing it there's
    Stuck in house with kids so can't get to my mates that has one
    Engine : 1.9 CDTi
    Normally the illumination circuit is 12v and there will be a resistor in the circuit to bring the led voltage down to what it needs to be.
    What is it your trying to do?
    Hanging Heaton
    23 Post(s)
    Mileage : 140k
    Was to wire something that needs 5v but fancied it coming on with key fob etc... Might still do it but do what I was going to do from the switched 12v, just butcher an old charger.
  1. Battery Light ON - 14.1 volts at battery
    By snapsnap in forum Electrical & ICE (including SatNav)
    Last Post: 6th December 2011, 13:55
  2. Dash switch illumination
    By family guy in forum Electrical & ICE (including SatNav)
    Last Post: 25th September 2010, 10:05
  3. Best head-unit illumination colour match to std Dash...
    By Dan_BlackSRi in forum Electrical & ICE (including SatNav)
    Last Post: 20th January 2009, 10:53
  4. Fuses
    By mickontherun in forum Vectra C / Signum Car Chat
    Last Post: 18th October 2007, 17:06
  5. Dash Illumination change.
    By Merick in forum Electrical & ICE (including SatNav)
    Last Post: 20th March 2007, 10:01
