Results 1 to 10 of 16
Thread: leak in boot!!
    Apr 2012
    manchester
    Vehicle : vectra sri cdti 120
    Trim : cdti/ sri
    Default leak in boot!!
    i seem to have a leak into the boot, which is settling in my spare wheel well. i have resealed the rear lights in and its still coming in. i now think its coming in through the sealed part of the top of the boot external channel. and i can't seem to get the roof rack trim off to re-seal the microscopic crack in the seal.. there is no listing in the haynes manual for this. can anyone explain how it comes off... thanks... my car is a 04 vectra sri hatchback
    Regular Member Das's Avatar
    Here
    33 Post(s)
    Vehicle : Lada
    Trim : Riva
    Engine : 6.0 V12
    Year : 1954
    Small screw driver under the very rear part of the trim at the boot lid(use a cloth to protect the paintwork) and just prise it upwards. Also worth checking the condition of the aerial seal, these perish and the water runs down the rear washer hose then drips and runs down the C pillar, down the back of the fuse box and on to the floor.
    Apr 2012
    manchester
    Trim : cdti/ sri
    how do you change the aerial seal it does look a little perished now you mention it ??
    Here
    33 Post(s)
    Vehicle : Lada
    Trim : Riva
    Engine : 6.0 V12
    Year : 1954
    Drop the roof lining, and its a 17mm spanner to undo the base. If its not too far gone try some silicone seal, or try to get another one from a scrappys. I found the one off a vec b fits pefectly.
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800
    Mileage : 126000
    Apr 2012
    manchester
    Trim : cdti/ sri
    thanks mate i'll have a look !!
    May 2012
    county durham
    Engine : 1.9 cdti 150
    Mileage : 145k
    mine also has a slight leak in left side of the boot & sometimes when starting the car ( in wet weather ) I get the " check safeguard " warning on the screen .
    my aerial is a bigger base than the vectra B ones , the car does not have sat nav so why would this be ?
    Apr 2012
    manchester
    Trim : cdti/ sri
    i'm gonna check aerial today cheers
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800
    Mileage : 126000
    Quote Originally Posted by rickh01 View Post
    cover the aerial mount up and see if any rain gets in
    Regular Member james chambers's Avatar
    Sunny Leicestershire
    Trim : SRI
    Engine : Y22SE
    Mileage : 100,000
    mine was leaking because of the body sealant had cracked and was dripping down the inside of the rear quater pannel, it's a quick fix with a tube of black silicone sealer and once it's gone off just touch it up with a touch up stick! sorted!
  1. Water leak in boot
    By Davyturner in forum Bodywork & Interior
    Last Post: 19th December 2012, 17:10
  2. vectra boot leak
    By hollywooddocker in forum Troubleshooting
    Last Post: 24th August 2012, 23:19
  3. Yet another boot leak question!!!!
    By blackveccyC in forum Bodywork & Interior
    Last Post: 23rd January 2011, 17:17
  4. leak in boot??
    By paul.sessions in forum Bodywork & Interior
    Last Post: 22nd September 2010, 21:42
  5. Water leak in boot
    By CRAiGi-bOY in forum Bodywork & Interior
    Last Post: 10th October 2007, 10:27
vectra c leak in boot onto alarm
