Results 1 to 10 of 18
Thread: vectra my most annoying car ever
    Apr 2012
    cambs
    Default vectra my most annoying car ever
    my 53 plate 2.2dti does an average of 52mpg ! this is a true figure i,ve not reset any trip to get this figure over a short period of time. i,ve had this car about 3 years now.
    it is i think a good looking car it has all i need in the way of extras. its powefull enough and roomy and has not let me down engine wise. there lies the problem because it seems pretty much everything else has.
    1/ washer jets clogged up
    2/headlight/side light bulbs fail all the time
    3/left side wiper control rod decided to fall off
    4/THE most annoying intermitent wiper control system ever designed ( and i use that word loosely)
    5/ an anti glare rear view mirror that does'nt anti glare
    6/the famous swiming pool in the passenger foot well
    7/then the famous fail of the blower system due to item 6 above
    8/heated seats now dont work
    9/parking sensor system now also does'nt work
    10/NO ONE INCLUDING VAUXHALL KNOWS WHAT RELAY IS FOR WHAT (ssshhhhh ! its a secret)
    11/rear badges jump ship as it seems they have had enough too
    one more thing not entirly just vectra's. a simple question. space saver wheels...... WHY?
    thankyou all. selling this car asap and will not vauxhall again
    At least you have onlu suffered each problem once, and it has been resolved
    I know many, many people that have reported the same problem over, and over again, only to be told "no fault found", and paying for it as well
    The Vectra is good value for money
    Sadly all other modern cars are pretty much the same now, designed to be thrown away after 3 years / 60K miles
    VIP-Member
    40 Post(s)
    Vehicle : `
    Trim : `
    Engine : `
    Year : `
    Mileage : `
    Rubber filter in washer bottle clogs up if you or the previous owner don't use screen wash
    New one on me
    Known fault, wipex make replacements cheaply.
    In what way? 1 touch up is intermittent, the roller switch then allows you to decide how often they wipe.
    Check the cable has not come off at the mirror or the rear fuse box.
    If you dont keep the drain hole clear it will get blocked. Remove the rubber drain and it will never get blocked again.
    Well documented and if you follow the above you wont have an issue.
    Check the fuses in the rear fuse box and the connectors under the seats.
    Not sure if there is a separate fuse for that
    PM Plasma, I think he might have a list of them
    Yea mine came off when I polished them.
    Why not a space saver? Most spare wheels never see the light of day, its all about cost. Think yourself lucky you have that, many cars now dont even come with a space saver, in fact there was an option to drop it and replace it with an emergency tyre inflation kit on the vec.
    Full Member gibbon7000's Avatar
    lincs
    If those are just your problems (which are all easily fixed) then I'd be more than happy.
    My other car. 1972 1641cc slammed beetle. On the road finally!!
    VIP-Member
    40 Post(s)
    Vehicle : `
    Trim : `
    Engine : `
    Year : `
    Mileage : `
    He should think himself lucky he doesn't have a CDTi, lol.
    May 2011
    Ashby-de-la-Zouch
    Trim : sri nav/Elite
    Engine : CDTI 150
    Year : 56
    Mileage : 130ish
    its not a big deal get insignia washer jets and check your scuttle panel more often then you wont have a puddle and a broken fan.
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800 non vvt
    Mileage : 138000
    May 2011
    Ashby-de-la-Zouch
    Engine : CDTI 150
    Year : 56
    Mileage : 130ish
    Quote Originally Posted by vectra ste View Post
    how many times do we get reminded lol.
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Mileage : 138000
    heavy rain here tonight sorry lol
    7000 viewings now on this post and people still have swimming pools in the car
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Mileage : 138000
    he could of had a bill like this
    1. Injector #3 wiring loom: This is a blatent design fault,l. Good news is it's cheap to fix, especially if you DIY.
    2. Throttle body: A manufacturing fault sometimes causes a solder joint to break. Easily and cheaply fixed with a soldering iron and some solder - usually no need to buy a new one.
    3. EGR valve: This can sometimes get clagged up and cause problems at 60-80k miles, maybe sooner if used on a lot of short journeys or around town. Usually cleaning fixes it, but sometimes a new one is required. This problem affects many modern diesels and is inflicted by EU emission regs. I don't consider this to be vauxhall's fault.100 pounds
    4. Intake manifold/swirl valves: Swirl valve bearings wear out at around 80-100k. Crap design, blame vauxhall entirely for this one. Only solution is to fit a complete new one. Not an easy DIY job, so expect to pay a garage around £700 for this.
    5. Dual Mass Flywheel: Usually knackered by 100k miles, maybe sooner if abused (harsh gear changes, stalling, etc). I'm in the same camp as many others on this forum - this has to be considered a very expensive service item as the same problem seems to afflict most car manufacturers. Not an easy DIY job, so expect to pay a garage around 650.00 pounds
    6. Diesel Particulate Filter:
  1. most annoying feature about the vectra
    Last Post: 23rd December 2011, 12:51
  2. Driver door annoying me!!Vectra C
    By 6580gareth in forum Vectra C / Signum Car Chat
    Last Post: 23rd July 2010, 16:34
  3. Annoying vectra!!
    By old cruiser in forum Vectra C / Signum Car Chat
    Last Post: 28th April 2009, 21:48
  4. Really, really annoying....
    By joejdx in forum Vectra C / Signum Car Chat
    Last Post: 23rd April 2009, 19:52
  5. I've just found something annoying about my Vectra
    By JagRigger in forum Vectra C / Signum Car Chat
    Last Post: 8th February 2009, 21:59
