Thread: ignition live
    Regular Member Nessy's Avatar
    Jul 2009
    Leeds
    Default ignition live
    just fitted a head unit into my 05 vectra SXI but need to know the ignition live wire colour as the stereo isn't shutting off with the ignition
    any ideas please
    cheers
    wirral
    36 Post(s)
    Vehicle : Mk1 renault scenic... I know I know but it drives
    Trim : Basic
    Engine : 1.6 16v
    Swap the red an yellow wires around
    Full Member Knight Rider's Avatar
    Apr 2008
    Motherwell
    Vehicle : Vectra C SRi 1.8vvti
    Trim : Sri
    Engine : 18.vvti
    Mileage : 29,500
    Jul 2009
    Leeds
    cheers pal this is the sat nav model sxi is it still the same colours ?
    Jul 2009
    Leeds
    just spoke to the lad that fitted it for me as I'm useless
    he said its not the same as usual with it being the satnav one and all the wires are different colours to usual
    he's saying we need to take the ignition live from the back of the 12v jack near the ashtray ... make sense or is there an easier way ??
    wirral
    36 Post(s)
    Trim : Basic
    Engine : 1.6 16v
    It will work doing it that way.a cant comment on the wiring as I haven't looked at one with sat nav for a while
    Jul 2009
    Leeds
    ok aslong as its safe to use the black wire on the 12v jack il let him do that seems easiest
    thanks mate
    Jul 2009
    Leeds
    seems after reading on here I've been a bit hasty taking out the cd-70 they seem pretty good I'm thinking il put it back in
    can i a/ connect my iPhone to it and b/ connect a sony xplod sub
    Regular Member GoldenWonder's Avatar
    Durham
    I had the problem with a JVC unit in my 2006 Vec. I wired the live (red on my one) to the live wire on the back of the ciggie lighter. Wasn't difficult and worked a treat - cd unit switched on and off with the ignition! Hardest part was getting the original Vx unit out of the mounting frame, it was tight as anything!
    Regular Member wardy23's Avatar
    Nov 2011
    North Yorkshire
    Vehicle : vectra
    Trim : sri
    Engine : 2.2
    Mileage : 64000
    bring you sub with you when you come just so i can have a look at it and i will be able to advise you what you need for it mate and im not sure about your iphone mate
  1. No ignition live please help
    By foxyland in forum Vectra C / Signum Troubleshooting
    Last Post: 12th December 2012, 22:49
  2. Wiring an amp, need an ignition live and permanent live in the boot
    By inchy1981 in forum Electrical & ICE (including SatNav)
    Last Post: 22nd November 2012, 16:36
  3. ignition live
    By glynn in forum Electrical & ICE (including SatNav)
    Last Post: 15th October 2007, 20:03
  4. ignition live
    By kenny22 in forum Electrical & ICE (including SatNav)
    Last Post: 14th June 2007, 22:35
  5. Ignition Live
    By leeds vectra in forum Electrical & ICE (including SatNav)
    Last Post: 4th December 2006, 01:20
