i have a compressor here that i changed today as my clutch was gone. took about 30 mins to change so if your clutch is ok you can have this and fit your clutch on. it was checked before i took it off and was not loosing pressure
As long as it is part 13265616 I will have that off you mate.
Clutch is fine, system gases up and works fine but loses pressure after a couple days with the compressor leak.
im sure it is but ill double check for you tonight
Hi mate checked the number on it and its 13171593 don't know if it will be any good to you but its here if you want it.
