Results 1 to 10 of 14
Thread: Change aircon compressor 1.9 CDTi (120) 57 plate
    Apr 2011
    Airdrie, Scotland
    Default Change aircon compressor 1.9 CDTi (120) 57 plate
    Need to get my aircon fixed as even in Scotland it's getting uncomfortably warm in the car.
    Tried to get it re-gassed but turns out compressor is goosed.
    So I am trying to source a used item but need a specific part number from the faulty compressor.
    How would I get access to the compressor firstly get the part number and then once I source a used part change it?
    Cheers.
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Is it the actual compressor or just the clutch? The clutch can be changed on it's own
    I did my dti compressor clutch using a s/h compressor from ebay. It saved having to disconnect the pipes etc.
    Apr 2011
    Airdrie, Scotland
    I was just told to get the compressor changed mate as it's leaking air everywhere.
    Forfar, Scotland
    Trim : LE/VXR
    Year : 13/07
    No problem bud
    Apr 2011
    Airdrie, Scotland
    Can anybody offer any advice on how to find the exact part number for this?
    How do I gain access to the comprssor?
    Regular Member JagRigger's Avatar
    Norfolk
    Engine : 1.8 VVT
    Mileage : lots !
    Did mine over the weekend in around an hour and a half. ( petrol 1.8 )
    I took the radiator fan and airbox out to improve access first. Then there is one plug to remove, the torx bolt holding the two pipes on and three mounting torx bolts.
    Don't forget to change the two seals on the pipes when you do !
    Take a look here for the part number:
    http://www.opeloem.com/opel/vectra_c...l_engines.html
    John - you still haven't told me how you got your clutch off
    Apr 2011
    Airdrie, Scotland
    Had a look at the site for the part number mate, have not got the foggiest how to get it from that.
    Norfolk
    Engine : 1.8 VVT
    Mileage : lots !
    OK - it depends on your chassis number.
    I'd suspect your compressor model number is 13197197 - ( several on e-bay at the moment ) but please take a look at the plate on your current one and check
    Apr 2011
    Airdrie, Scotland
    Just to double check, this will be the last 8 digits from the chassis number, in my case 71127168?
    Oct 2009
    Luton
    13265616 is for you.
    FYI - it's the last 8 digits of your VIN so.....
    7 = Model year (2007)
    1= Production plant (Rueselshiem, Germany)
    127168 = serial number, resets every model year
  1. Aircon compressor clutch
    By MattBrowning in forum Electrical & ICE (including SatNav)
    Last Post: 21st July 2012, 12:50
  2. Zafira aircon compressor
    By JherekC in forum Electrical & ICE (including SatNav)
    Last Post: 13th May 2012, 09:29
  3. Aircon Compressor - Where in the N.E.?
    By mpc in forum North East RO Vacant - ARO - Vacant
    Last Post: 21st November 2011, 16:10
  4. AirCon Compressor
    By scottymf in forum Bodywork & Interior
    Last Post: 19th June 2008, 19:28
  5. aircon compressor
    By The-Bandit in forum Parts for sale
    Last Post: 4th May 2008, 23:22
vectra c aircon compressor removal
1.9 cdti aircon
1.9 cdti aircon compressor removal
