Page 1 of 6 123 ... LastLast
Results 1 to 10 of 51
Thread: White smoke
    May 2012
    Scarborough
    Exclamation White smoke
    Plumes of white smoke after 80mile of running , turn engine restart fault gone 80 mile later. Smokes again , 1.9 deisel signum 2004 ,
    Had done New turbo. Forced regen. Dpf. Leaned , egr removed and cleaned. New air mass filter tried.
    Any advice welcome. Also oil light now comes on amber / yellow reset if. Ad engine turned off this only started after egr removed , help please
    Sounds like water is getting into the oil, when the engine is warm/hot
    Take a look at the coolant condition and sniff test
    When you switch off the engine, listen for bubbling / gurggling noises
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    Sounds like head gasket failure
    ---Sent from my iPhone 4 using Forum Runner.
    May 2012
    Scarborough
    Sorry should have said had top end rebuild new gasket and tested also why would stopping engine for 3 seconds whilst car still moving stop the white smoke the gasket could not repair itself , coolant level not moved , the smoke is smoke I did not say steam !
    May 2012
    Scarborough
    Thanks for trying though all the same ,
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Egr cooler.
    Gives same symptoms of headgasket
    May 2012
    Scarborough
    Smoke smells of deisel not steam would that still be cooler ?
    The reason you are getting white smoke is due to oil and water mixing, and then being superheated very quickly (turning into steam)
    May 2012
    Scarborough
    Ok so why when I turn the ignition off deis it disappear , dies the water think oh I'll not mix now cos the engine is still as hot ie went 240 miles in car it happened at 76 miles on motorway turned off ignition at 60 mile about dipped clutch turned ignition on did a rolling bump start engine off for 3 seconds not time to cool down fault went did same at 152 miles did it again at 239 miles that's not water gettin in anywhere its smoke not steam !!!
    May 2012
    Scarborough
    Something like regen is coming on and staying on a valve or something relay sticking any proper ideas any one please don't mention water again as I know it's not water coolant level not changed in over 4000 miles
  1. Replies: 18
    Last Post: 20th November 2012, 21:41
  2. white smoke help
    By smartalec0310 in forum Engine & Drivetrain
    Last Post: 29th June 2012, 22:59
  3. white smoke help
    By smartalec0310 in forum Styling
    Last Post: 25th June 2012, 18:32
  4. White smoke!
    By stickygreen in forum Engine & Drivetrain
    Last Post: 1st February 2012, 19:02
  5. White Smoke???
    By MistyMorning in forum Engine & Drivetrain
    Last Post: 4th February 2011, 17:37
