Thread: New To Vectra C - Please Help
    Regular Member DANNYGRAY's Avatar
    May 2012
    sunderland
    rolleyes New To Vectra C - Please Help
    Hello everyone. ive had a vectra b for about 18 months and decided to upgrade to a vectra c. i bought a vectra c sxi 1.8 2002 reg. and the owner didnt know when the timing belt and etc had been done. i noticed the temperature gauge was going up to about 80'C and then dropping and staying around 0 or 60'C (the lowest the gauge can go). so i got all this work done today ..
    timing belt kit.
    auxillary belt.
    spark plugs.
    thermostat and casing (including temp sensor)
    water pump
    fuel and oil filter
    but yet the temperature seems to dip between just under 70 and just under 90'C. but doesnt go down to 0 like before. is this normal? the temp hasnt dropped back down to 0 yet. i gave it a good rev about the estate after all this was done and its done about another 20 miles today so i know its worn in. im not sure if im getting realy bad mpg anymore but it dropped about a quarter of a tank in about 68 miles before this was done. the heaters are fine but when i stop at traffic lights or whatever the heaters cool down abit till i give it some revs. im not sure if this is normal as i havent has this car more than a week. sorry if this thread has been covered but i havent found one that describes my problem. any help would be nice. if its not the thermostat what could it be? i presume its not head gasket as its not over heating and i havent lost warm heating. is there another temp sensor? any help will be much appreciated. thanks
    VIP-Member
    Dec 2010
    London
    Engine : Z18XER
    Could be an air lock
    Wirral, UK
    Vehicle : Mokka
    Trim : SE - Orange Rock 's !!
    Engine : 1.7CDTi
    It could also be a problem with the coolant pump, which I think is driven by the aux belt.
    VIP-Member
    Dec 2010
    London
    Engine : Z18XER
    Thats only on VVt engine he will have an Z18XE which is run off timing belt both of which he has changed
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800 non vvt
    Mileage : 142000
    ive got a 1.8 ls 2004 i changed my thermostat and it takes about 3 miles to get to 86 and it stays there
    thats with no heater on
    sometimes it goes to 92 when stuck in traffic then the fan cuts in back around 86-88
  1. mods could i do to my vectra 1.9cdti vectra suggestion of cheap vxr bumpers
    By lynchy-- in forum Vectra C / Signum Car Chat
    Last Post: 6th January 2013, 00:17
  2. Vectra b rose bush for vectra c rear upper control arm
    By supernova_abh in forum Suspension, Wheels & Brakes
    Last Post: 14th September 2012, 19:26
  3. Silver Vectra (Vectra C Sticker) Southport Ocean Plaza DU56
    By mishima in forum Spotted or put a flyer on a Vectra C/Signum or Insignia?
    Last Post: 29th September 2011, 23:25
  4. Replies: 9
    Last Post: 17th July 2009, 12:07
