Thread: More on The A/C Compressor
    Regular Member RobW's Avatar
    Tain - Easter Ross
    Default More on The A/C Compressor
    Looking on ebay and there's quite a few but are they the same between different engines? Can I get one for an 8v CDTi or a 2.2 petrol for my 150 CDTi?
    Full Member
    Nov 2009
    Warrington
    How do you know if the compressor is faulty ?? my Ac is faulty (sorry can't answer your question)
    Regular Member JagRigger's Avatar
    Norfolk
    Engine : 1.8 VVT
    Mileage : lots !
    Go here and find the right part number
    http://www.opeloem.com/opel/vectra_c_2002_/body_interior_fittings/air_conditioning/
    Then e-bay that. Remember to change the seals too.
    Did mine yesterday in a little over an hour
    Tain - Easter Ross
    Quote Originally Posted by rob warrington View Post
    Had it pressure tested and plenty of gas and checked the volts at the plug onto the compressor and there is power to it so it has to be the compressor.
    Full Member
    Nov 2009
    Warrington
    Quote Originally Posted by RobW View Post
    i had mine re gassed last week before our trip away, as soon as we got opn the m6 and turned the ac on it was blowing coolish air wasnt cold at all. ranfg the guy who did it so were going to take it back so he can test for leaks. knowing my luck its gonna cost a bomb to repair. hope you get it sorted buddy.
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Is your car filled with gas? To save having to get it de-gassed and re-gassed just change the clutch. It's not uncommon for the electromagnet to pack up on them
    Norfolk
    Engine : 1.8 VVT
    Mileage : lots !
    John - have you changed the clutch ? If so how did you get the old one offthe compressor shaft. Been trying on my removed unit and I cant shift it ( plate and circlip removed )
    Jun 2011
    manchester uk
    hi i am having the same problem, did you manage to remove the compressor clutch in situ if so how/what tools did you use how did you manage it, thanks. simon
  1. Air Con Compressor
    By Siggy08 in forum Vectra C / Signum Car Chat
    Last Post: 28th November 2012, 15:52
  2. Air con compressor
    By keith1983 in forum Electrical & ICE (including SatNav)
    Last Post: 28th November 2009, 19:20
  3. air compressor
    Last Post: 18th November 2009, 07:56
