Thread: cooling system problems
    Full Member vmb2722's Avatar
    May 2012
    Blackpool/St Mary's Bay
    Trim : Exclusiv
    Engine : 1.9 CDTi 150
    Default cooling system problems
    I have a 56 plate vectra 1.9tdci 150 and I have just replaced the thermostat now the temp guage is going off the scale but the radiator is stone cold, anyone know what I need to do?
    Wondering lonely as a cloud
    26 Post(s)
    Vehicle : M5
    Trim : Nothing needs adding
    Engine : 5.0 V10
    Year : 07
    Mileage : 37000
    Looks like an airlock mate have you opened the bleed screw and vented the air out
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    Remember to bleed it with the cabin air temp set to full hot
    And don't over tighten the bleed screw. I learnt the hard way!!
    ---Sent from my iPhone 4 using Forum Runner.
    May 2012
    Trim : Exclusiv
    X
    Quote Originally Posted by tony-1977 View Post
    Can you get new ones?
    26 Post(s)
    Vehicle : M5
    Engine : 5.0 V10
    Year : 07
    Mileage : 37000
    Quote Originally Posted by vmb2722 View Post
    X
    Yes you can mate in the pipe it is fitted to at a cost of £121 from the dealers you can get one from the scrappies but best to be careful works most every time
    May 2012
    Trim : Exclusiv
    ok, so i tried what was suggested and even took the pipes off the heater matrix as suggested by the haynes manual, its sitting now at 90 degrees with no overheating but my cabin heater is blowing hot one minute and then lukewarm the next. Any ideas?
    26 Post(s)
    Vehicle : M5
    Engine : 5.0 V10
    Year : 07
    Mileage : 37000
    Theres still air in there mate try running it without the expansion tank cap on from cold until the engine heats up thats how I did mine recently no issues with airlocks
    May 2012
    Trim : Exclusiv
    Problem Solved, it worked for a while but went bad again, it was fine on some journeys but overheating on others, the pipe from the thermostat seemed to get cooler the further away it got from the engine, i suspected the waterpump so purchased a new one, on removing the old one the impellor had come away from the shaft. all replaced now and working fantasticaly, thankyou all for your help!
  1. Cooling system help
    By Tinks in forum South Central (ARO - matty2fatty)
    Last Post: 11th December 2012, 21:37
  2. Cooling system
    By Tinks in forum Engine & Drivetrain
    Last Post: 21st April 2012, 10:43
  3. Cooling System Operation Question
    By sjanisz in forum Vectra C / Signum Car Chat
    Last Post: 16th June 2011, 10:07
  4. some probs cooling system
    By decks in forum Vectra C / Signum Car Chat
    Last Post: 15th February 2010, 18:00
  5. Cooling system performance problem
    By brianjamesreed in forum Engine & Drivetrain
    Last Post: 19th July 2009, 22:55
how does the cooling system work on vectra
How to bleed a radiator in a 1.9tdci vectra c
