Thread: Air con question.
    Jun 2012
    swansea
    Default Air con question.
    Recently purchased my 2006 Vectra SRI Nav and the air con wasnt working. Took it to a local garage to have it regassed and it worked fine for 2 days but then the air coming out of the vents stopped blowing cold. The compressor is engaging and working fine so i took it back to the guy who regassed it for me as he put dye in when he regassed it. Using the UV goggles he found a leak in my air con condensor. Would a small leak in the air con condensor cause the air not to blow cold anymore? Theres obviously still some gas in there or the compressor wouldnt be engaging. only asking as i would be gutted spending a couple of hundred pounds on getting the condensor changed and the system regassed only to find out it hasnt cured the problem. Any thoughts would be greatly appreciated.
    May 2011
    Ashby-de-la-Zouch
    Trim : sri nav/Elite
    Engine : CDTI 150
    Year : 56
    Mileage : 130ish
    my condensor went a year ago at 123k cost £300 to fix but its ice cold now
    Jun 2012
    swansea
    When you press the air con button and the compressor kicks in do you getting a noticable hissing noise from behind the centre air vents. Mine does, i was just wondering is that normal?
    May 2011
    Ashby-de-la-Zouch
    Engine : CDTI 150
    Year : 56
    Mileage : 130ish
    i don't know ill have a look for you
    Jun 2012
    swansea
    nice 1
    May 2011
    Ashby-de-la-Zouch
    Engine : CDTI 150
    Year : 56
    Mileage : 130ish
    when i first turn it on it make a noticeable hiss then goes quiet.
    Jun 2012
    swansea
    aaah so it is normal then. Looks like im gonna have to change the air con condenser then and hope it does the trick. I just thought even though mine has a slight leak the air would still blow cold as theres obviously still gas in the system. I'll be gutted if i change it and it doesnt cure the problem. Thanks for having a look mate, nice 1
    Jun 2012
    swansea
    changed the condensor and it works like a dream now.......blowing ice cold 2 months down the line
  1. GSI Inner tie rod question.
    By Lee_gsi in forum Suspension, Wheels & Brakes
    Last Post: 9th August 2011, 19:46
  2. question about hid
    By marc vectra sri in forum Electrical & ICE (including SatNav)
    Last Post: 22nd July 2011, 23:15
  3. Vaux-Com / Op-Com question - Screen change question
    Last Post: 16th May 2010, 23:54
  4. Just a question...!
    By Maxim007 in forum Styling
    Last Post: 26th January 2010, 20:12
  5. BSR question
    By soulman in forum Vectra C / Signum Car Chat
    Last Post: 6th October 2007, 22:55
